DC 175.4 settings question - Car Audio Classifieds!
Old 09-11-2015, 03:43 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Default DC 175.4 settings question
How do I set this up for 4 Neopro 10's bridged at 4 ohms? I have 2 ST350's on their own amp and need help with crossing this 1 and recommended crossover points.
Old 09-11-2015, 05:18 AM
Unless you've got some mids in the mix, you won't be able to use the low-pass filter at all because it only goes to 300hz. That makes it easier to set up though. Adjust your gain first and turn off the subs so they mask any distortion from the NeoPros. Play whatever music you listen to and adjust the high-pass to a point where they aren't bottoming out on low notes at full volume. I'd start off somewhere around 12-2 o'clock on those dials.
Old 09-11-2015, 03:47 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Would it make it a night and day difference to switch amps that actually have crossovers? How can both LPF and HPF go to 300hz? No multipliers, nothing....I don't want the 10's to play above a certain point either though
Old 09-11-2015, 08:10 PM
You could go the inexpensive route and add some passive inductance to form a low-pass filter. A coil (inductor) of about 0.3 mH wired in series with the positive or negative lead of each of the Neopro's would give you a 6dB/oct LPF of about 2khz.
Depending on how the 10"s are installed you might not need a lot of filtering on the higher end. Larger speakers will naturally roll-off at higher frequencies, and "stacking" them by using multiples will further reduce the off-axis high frequency information by decreasing the beaming frequency.
If it was me I'd prefer to have some kind of active filtering though, either through a DSP or an amp capable of higher frequency points with the crossovers, but If I didn't have anything at my disposal I'd still install everything and set it up like I described in the above post just to see how it sounded.
Scapelli21 (09-12-2015)
Old 09-12-2015, 04:42 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Would using my 80PRS help at all for tuning? I might just end up switching amps as it seems REALLY stupid to need a bunch of extra shit just to use an amp
Old 09-12-2015, 07:42 AM
I think you can use the 80prs for crossover duties. I seem to remember it only going down to 1.25khz for the high-pass channel, but I'm not sure if there's any limitations on the low-pass side. I guess it will also depend on how many different speakers you're running. If its subs/midbass/tweeters I'm pretty sure the 80prs can handle that. If you've got other crossover needs besides those you'll have to get more creative, lol.
settings gains gotbass1990 General Car Audio Discussion & Questions 17 09-22-2015 07:53 AM
Vcm settings!? Tiller General Car Audio Discussion & Questions 8 01-09-2013 08:01 AM
Amp Settings Saginawbum1234 General Car Audio Discussion & Questions 6 12-31-2012 12:43 PM
electrical help and hu settings ltr450racer690 General Car Audio Discussion & Questions 28 02-12-2011 02:49 PM
amp settings gbo559 General Car Audio Discussion & Questions 19 03-16-2010 01:55 AM
