no bass from 6x9 - Car Audio Classifieds!
Old 09-11-2015, 08:44 AM
West1's Avatar
0/11 ssssss231
Default no bass from Image Dynamics xs69
took my truck to get my lows and highs rewired. While their, I asked them to put in some new 6x9's I picked up.
I've read mad positive reviews about these and how they can kick up some sweet bass for mids. Because I hear no bass (all highs), I thought it was my amp settings (currently set on Full) and looked at settings on my NEX-4100, eq is in the middle and digital crossover doesn't give me much of a sound difference while playing with the settings.
Few questions...
I pop'd open the component crossover and noticed there are pins with a black cap, am I to play with these (as seen in the pic)?
The 6x9 has another set of terminals but they are aidle, nothing is connected to them. Are they supposed to be wired in with the active terminals?
Or is it just a crap audiobahn amp (next on my upgrade list)??
Thanks for the help peeps
Purchased from- Melverc/SA Amp
Old 09-11-2015, 09:51 AM
mega fatty
0/11 sssss6008
What 6x9's are those
It's hard to see anything in the pictures
Old 09-11-2015, 09:57 AM
West1's Avatar
0/11 ssssss231
Image Dynamics xs69
Lets see if these are better pics
Old 09-11-2015, 10:24 AM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
I believe those idle terminals are used for the tweeter when you mount them to the on the 6x9 in a coax configuration.
Looking at the crossover, it looks as though you may want to fiddle with the jumpers on the lower left as I see low-pass and all-pass selections, either that, or you may want to review your head unit settings to see if you have a high-pass xover set too high
who wants a nudel ride?
The Following User Says Thank You to Nudels For This Useful Post:
West1 (09-11-2015)
Old 09-11-2015, 10:42 AM
West1's Avatar
0/11 ssssss231
Thanks. My first thought was messing with the jumpers, just wasn't sure as I've never had or heard of crossovers having this option. Will play with it in a few hrs
Old 09-11-2015, 11:33 AM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
oh yeah, many passive crossovers of higher quality over the years have had jumpers or selector switches for roll off/roll in and response curves,.. some even had passive eq's
try this to troubleshoot the issue,... power the 6x9 directly off the amp without the passive xover at LOW volume,... if you have a low pass setting on the amp, use it. if you get the lower freq's youve been missing, it is your passive xover, if you dont, it's somewhere in your signal chain between head unit and amp
West1 (09-11-2015)
Old 09-11-2015, 11:56 AM
West1's Avatar
0/11 ssssss231
Will do, Thanks
Old 09-11-2015, 02:08 PM
West1's Avatar
0/11 ssssss231
Just opened my door on lunch.
Put 6x9 directly to amp, sounds the same. Switched the amp to LFP and the 6x9 sounds like its under water, still no bass. HFP sounds like super earbuds, good highs but no bass around.
Wired back to crossover and started messign with the little black caps (all 3 settings), the sound changes but only effects the highs. Slim to none on the Low Freq of the crossover.
Could be my wiring on the amp or it has to be between HU and amp?
I messed with all the eq/crossover/fade/speaker volume on the HU and I don't see much of a difference on mids/bass with my SUb off.
Old 09-11-2015, 02:22 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
yeah, its gotta be something in your signal chain,... id start by using jumper rca's from the head unit directly to the amp to see if it's either the digi crossover or eq, if you get a better spectrum with the midbass, eliminate the possibility of each component using the jumper rcas working your way forward to the source
Old 09-11-2015, 02:36 PM
West1's Avatar
0/11 ssssss231
Dang it, im hoping its just my amp taking a dive. Wiring on HU and Amps is all brand spanking new. Within a month. I really appreciate the help!!
Looking for 6x9's to fill in my low/mid bass skuppej General Car Audio Discussion & Questions 11 09-08-2014 08:56 PM
6x9 adapter brackets(NEW) Kicker bass knob wet_rat Wiring, Electrical & Other Installation Equipment 0 11-16-2012 03:58 PM
American Bass VFL 6x9 Midrange Speakers 46panel Component & Coaxial Speakers 3 11-27-2011 03:54 AM
Best SQ 6x9 rxer311 General Car Audio Discussion & Questions 15 08-11-2011 07:36 PM
Cadence 6x9 mid-bass Jh8909 General Car Audio Discussion & Questions 1 10-18-2010 08:10 PM
