Amp and battery spark - Car Audio Classifieds!
Old 09-12-2015, 08:14 PM
0/11 sssssss29
Default Amp and battery spark
Everytime I hook up an amp to a battery I get a large spark. It doesn't matter if I connect the positive or negative lead first. It also doesn't matter if I connect the amp first than the battery second, or vice versa. I even tried connecting an amp to a stand alone battery in my living room just to see it power on and I still got the spark.
I would like to avoid this spark issue because it leaves a nasty mark on the amp inputs and battery terminal. Can anyone provide me with any advice to prevent this from happening. I would greatly appreciate it.
Old 09-12-2015, 08:23 PM
0/11 ssssss427
Resistor.
Build log:
High resolution photos:
Old 09-12-2015, 08:28 PM
massivespl's Avatar
0/11 sssss8409
Put wire in amp first and then connect them to battery bank or whatever
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-12-2015, 08:40 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Just arc it on the tool you're using for the set screws for a sec
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 09-12-2015, 08:45 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
the spark is the initial charge of the internal amp caps.
bump4life (09-22-2015)
Old 09-12-2015, 08:59 PM
rdooski3's Avatar
0/11 ssssss625
Take your power wire fuse out first.....or what massive said if your setup is more complex.
andamanauctions -
"Center speaker has been cut, possibly by manufacturer and appears to be professionally repaired with black tape. This appears very professional and might be by design. The tape used is not some cheap electrical tape, but a light fabric-like tape. I assume if you are bidding on this high-end speaker, that you are an audiophile and aware of the origins of the anomaly."
Old 09-12-2015, 09:51 PM
0/11 sssssss29
TaylorFade, are you saying I can take my live wire that is connected to the negative battery terminal and touch it to an allen wrench to get the spark, than attach it to my amp terminal with no spark. Can I than do the same with the live wire that is connected to the positive battery terminal. Will either of these actions affect my batteries in any way because one is an XS Power Lithium 15K and the other is an XS Power D3100.
Old 09-12-2015, 09:56 PM
Authorized Vendor
0/11 ssss14115
ones the amp sparks, its charged for ~30 sec for a minimal arc. touching it to the terminal will pre charge it. you only need to do it to one polarity (I suggest negative)
Old 09-12-2015, 09:57 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Yes. That's what I do. My screwdriver and 'T' handle are scarred like a mofo. Lol.
I'm not sure what you mean about the battery terminal one. Like Jeff said... it's just charging up the caps in the amp. Something has to get that shit in there. Better the tool you're using than your buss bar or terminals or whatever.
If the option exists though... best bet is to use the inline fuse (which you should have out already anyway).
4x world champ
- Floyd E. Toole
Old 09-12-2015, 10:11 PM
mega fatty
0/11 sssss6008
When repairing my amp I put a halogen bulb in series with the amp terminals
It slows the charge up rate to about 2 seconds
Or simplest would be Taylor's way
E3 spark plugs kicker55 General Automotive Chat 8 04-05-2011 10:53 AM
Spark or no spark - I have such a dumb question??? chip_fish_roberts General Car Audio Discussion & Questions 14 08-29-2010 05:37 PM
No spark on a 1999 toyota camrey mattintc10 General Car Audio Discussion & Questions 8 08-10-2010 05:08 PM
[SOLD] MSD 8.5mm Super Conductor Spark Plug Wires for Toyota toolguy420 Miscellaneous Stuff For Sale 10 08-28-2009 06:57 PM
motor / spark plug help needed. RollerDJ General Automotive Chat 103 04-04-2009 10:31 AM
