Actual requirements to run a 3k substage - Car Audio Classifieds!
Old 09-13-2015, 10:33 PM
0/11 sssssss49
Default Actual requirements to run a 3k substage
I currently have an stock electrical system. I want to be able to run a 2.5-3k system. I figure building for the higher end will save me headaches in the future. The vehicle is Base 2002 Chevrolet Cavalier. I know I have room for (3) Group 31 batteries where the spare tire used to sit. Any and all help/suggestions are greatly appreciated.
Old 09-13-2015, 10:43 PM
Super Moderators
0/11 sssss9623
bare minimums or best bet
Old 09-13-2015, 10:46 PM
Silver03gt's Avatar
0/11 ssssss687
I have a 275 amp alt and 4 red tops. I only charge at around 13.4-13.5. At my amp I normally measure 13.4. At full tilt I drop to around 12.2 at 2 ohm. At .8 ohm I would drop low 11s. If I had some good good g31s id imagine id hold pretty stable.
2017 Chevrolet Silverado LT 1500 - Mechman 320 amp alt, possibly 4 DC M3 8s center console, some 3k amp.
2005 Ford F150 - bagged on 24s. Maybe new sound vehicle. (SOLD)
Old 09-13-2015, 10:56 PM
mega fatty
0/11 sssss6008
A 250a alt and a good battery up front and one big battery in back
Old 09-13-2015, 10:58 PM
0/11 sssssss49
Best bet
Old 09-13-2015, 11:03 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
HO alt + OEM size AGM + G31
You can sub (2) banks of caps for the G31 if you like.
That's a real solid setup.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 09-14-2015, 01:43 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
3k rated or clamped? And what ohm load? 3k at 1 ohm could be sustained with a HO alt and single big battery under the hood.
Current Build:
#60sHereIcome
Old 09-14-2015, 03:02 AM
0/11 sssssss49
3k rated @ 1ohm
Old 09-14-2015, 03:11 AM
KickinBlazer's Avatar
0/11 sssss1122
HO alt (275 or more)...stock size AGM up front and 1 or 2 G31's in back...2 would give you more reserve and prolly keep voltages higher
if its to loud your to old!
Old 09-14-2015, 03:20 AM
0/11 sssssss49
Email from Singer:
Any of these options work with your vehicle if you use a longer bolt to mount the larger cases (ad244 or larger)
MDL * * * * * * * *PRICE * * * * * *IDLE OUTPUT * * * * *
220A * * * * * * * $389 * * * * * * * 140A (ideal for up to 2-3K RMS daily) stock case upgrade
larger case options (ad244 and up)
250A * * * * * * * $429 * * * * * * * 160A (ideal for up to 4-5K RMS daily) * * * * *
275A * * * * * * * $449 * * * * * * * 170A*
350A * * * * * * * $569 * * * * * * * 200A (ideal for up to 6-8K RMS daily)
6 phase option
320A * * * * * * * $639 * * * * * * * 220A+ (best for idle performance in a 5-7K application)
All units come w/ a lifetime warranty that covers any labor and return shipping (just not parts) You can add a powder coating option on any order for an additional $48.
-mike
So I need to find a group 75 AGM for up front.
X-10 Enclosure Requirements 02ls1s10 (Sundown Audio) 1 06-09-2014 03:32 PM
New Section...With Requirements: Benny33 General Car Audio Discussion & Questions 38 09-19-2011 03:12 PM
Port Requirements For SA-12's 350zkid (Sundown Audio) 34 08-07-2011 07:59 PM
going active, amp requirements? nicyousuckk General Car Audio Discussion & Questions 12 07-21-2011 10:04 PM
