Put my two FI BL 10's head to head against a Shocker Sig Neo 12 on Saturday - Car Audio Classifieds!
Old 09-14-2015, 07:05 AM
CRXBMPN's Avatar
Central Maine Bass Head
0/11 ssssss209
Default Put my two FI BL 10's head to head against a Shocker Sig Neo 12 on Saturday
I had a show yesterday and was able to bring two different setups out to play with. One of them I've had for a couple yrs - two FI BL 10 dual 2's. Recently at a show I had the surrounds let go on them and one of the dust caps blow off on my second run of the day. I was able to get a decent number off with two Sundown NS1's on them @ 1 ohm each on the first run, but I think they were beginning their death spiral and my max # was not achieved. I gooped the dogpoopie out of them and threw them back in the box and in the car for the show on Saturday.
My second setup is a Shocker Sig Neo 12 dual 2.8 that I borrowed from a local competitor to test with, and I put together a 2.25 cube box for it with two 6" aero's. It and the FI box are fairly similar, but I was not sure about the numbers either would put up due to lack of test time.
Here is the FI box, got an NS1 under it (not hooked up in the picture) and another in the rear... NS1's are @1 ohm each
The subs all gooped up
Here is the Neo, and a few progress pics... NS1's are at .7 ohm each
I've got some videos I'll post up when they all get uploaded as well.
On both of my runs, after I rolled my volume up and held it, the Kenwood deck face went dark and it would not roll down or shut off. First run I powered it down and after about 4 seconds it turned itself back on and began another death burp at max volume. I had to yank the deck face off, and then it permanently shut off... that scared me, and my FI's smelled like they went through an old school db drag 5 min death match, with smoke coming out the ports O_o I only got one 60 or 61hz burp out of the Neo, and then I had to yank the deck face, but a number showed and it's something to work with.
Anyone got a guess as to what either did in this little guy?
Team Bass Lovers Of MainE/The Loud Crowd/CentralMaineBassHeads
2k5 SLAP Stock 2 National Champion - I feel old...!
1991 CRX, 2 x Sundown NS1's, Batcap 4000, couple other batts, 2 x FI BL 10's - 153.4 dash/155.9 outlaw
Shocker Sig 12 - 153.7 dash
Old 09-14-2015, 07:25 AM
CRXBMPN's Avatar
0/11 ssssss209
I also threw my GoPro on my head for about 20 minutes during the show, including my first run where I have the deck sh1t out on me. Here that is if anyone wants to waste 1/3 of an hour listening to us Maine'ahz. Exo makes an appearance as well in it!
https://www.youtube.com/watch?v=M1csLZ8hnUY
Old 09-14-2015, 07:29 AM
72impala's Avatar
0/11 sssss1706
Feedback Score: 68 reviews
155 dash bl's
, 154.6 dash shocker sig
My guesses
2003 6.8L V10 Excursion Limited
2015 MECA STREET 5 WORLD CHAMP
Old 09-14-2015, 07:33 AM
CRXBMPN's Avatar
0/11 ssssss209
damn you are one optimistic mofo LoL
If I dropped the BL's to .25 ohm on the NS1's maybe, but I don't think they could take that much more power. The Sig I only got one burp out of at an assumed frequency, unfortunately.
Old 09-14-2015, 07:59 AM
72impala's Avatar
0/11 sssss1706
I was going off your sig scores, doubled your power and made a guess. (Since you have bigger amps now). Oh well. I wish "hispl" would sell me his 4 neo sig motors. He still have them?
Old 09-14-2015, 08:12 AM
massivespl's Avatar
0/11 sssss8409
I seen a few crx with setups like this. Sub front and port back. Which I think is weird as fawk.. Have you tried sub up port back? Or port on same plane as the woofer? It just seems like sub on front of box and port on back wouldn't work proper and be able to build pressure in the box
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-14-2015, 08:28 AM
doug118's Avatar
0/11 sssss4674
Sub front port back in a crx is like sub up port back in our trucks. It's just what gets the loudest
Old 09-14-2015, 08:29 AM
CRXBMPN's Avatar
0/11 ssssss209
This motor is his, along with his four Neo Sig 15's in his Jeep wall on eight Zed 1200w amps. We live less than an hour from each other too so it makes it very easy. I believe he is going to be building me up three subs with similar or same softies as the Neo, just TC9 motors. For some 1500w RMS subs, these FI's have done alarmingly well, I'm so impressed it's unreal.
For shi-grins I may build an exact duplicate box as the Neo 12 is in now, and only fire it up instead of forward, just to see if there is a difference. It's a bit exotic, but alot of CRX style boxes are subs forward and ports rear, be it in a box or sonotubes.
FWIW - 153.4 with the FI's , 152.6 with the Neo.
Import Face Off is coming up, which is a USAC event, I would be curious to see what my outlaw #'s are. When I did a 153.1 in my garage recently testing the FI's, I was able to pop a 155.9 at the kick. If the math stays the same, I could see mid 56's outlaw with reinforced Goop'd subs. Could always drop the amps to .25 as well......
Old 09-14-2015, 08:31 AM
72impala's Avatar
0/11 sssss1706
Ask him if he wants to sell his neo sigs to me ; )
OR trade for some other neo motors
Old 09-14-2015, 08:34 AM
0/11 ssssss391
Those 10's are absolutely at mechanical limits, that's why the surrounds peeled off to begin with. The surrounds are being stretched flat out.
That 12" neo wasn't close to x-max so I'd bet that impedance rise is a factor. Coils in series free-air that sub has 20 ohm impedance at 60hz (44 ohm z-max @ 46hz)...... so extrapolate that to @ close to 6 ohms in parallel. I never pulled TSPs in parallel because I was always using the Crown 6K and used coils series subs parallel.
Bigger box, or if you dare, rebuild with D1.4 coil might help or might blow something up? We really need to buy DATS for testing up this way.
Also there's only the one batcap on those amps so whether or not double power is happening is anybody's guess.
FYI I'd sell the 12 he is using. I'd consider trading my 4 out of the Jeep for some LMS 5400's and that's about all.... otherwise you'll have to pry them from my cold dead hands. The motor force is obscene and the weight savings over any ferrite motor I'd bother with is just tremendous.
The Following User Says Thank You to hispls For This Useful Post:
CRXBMPN (09-14-2015)
WTB: shocker sig neo sub / motors TheLow Wanting to Buy (WTB) 18 04-24-2013 08:03 PM
18 atomic,dc lvl4 xl, shocker neo sig blazed_obsession Wanting to Buy (WTB) 25 11-24-2010 02:12 PM
[SOLD] Shocker Neo Sig 12's ssackett 12" Subwoofers 31 10-16-2010 08:39 PM
Shocker NEO Sig 15's! TeamPSI (Fix My Speaker) 11 04-22-2010 10:11 AM
Shocker sig neo motors for sale Ihrcke04 Speaker Accessories & Parts 68 11-09-2009 12:28 PM
