DS18 "Brazillian" Korean Zenon made amp - Car Audio Classifieds!
Old 09-15-2015, 07:18 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Default DS18 "Brazillian" Korean Zenon made amp
Stumbled upon this on fb.
*PRO-FR9000.1**
*Korean made, ZENON Board*
This is a full range amplifier. It is very similar technology as the brazillian amplifiers but made by Zenon. Zenon is one of the best amplifier companies on the planet hands down!
BIG POWER small chassis.
(L) 21.25"(W) 9.05"(H) 2.75"
Rated at
12.6v
4ohm-6500 Watts RMS
2ohm-7500 Watts RMS
1ohm-8500 Watts RMS
13.8v
4ohm-6800 Watts RMS
2ohm-7900 Watts RMS
1ohm-9000 Watts RMS
14.4v
4ohm-7000 Watts RMS
2ohm-8250 Watts RMS
1ohm-9500 Watts RMS
$850+ shipping
Authorized DS18 Dealer.
All our products are brand new with warranty.
The pictures are clearly of the 6000 model sorry for not catching that:
Engineered in the US, manufactured in South Korea, and independently tested vs. competing amplifiers, the smoothness, color, and design are just the cherry on top of the amazing technology and quality control these amps feature.With MOSFET PSU transistors, unbalanced RCA inputs, full range RCA outputs, variable input level control and a thermal, over-load, output direct, and speaker short circuit four-way protection circuit.These high efficiency, powerful amps will power all the high frequency speakers you want... and then some. Perfect for midranges, coaxials, tweeters, drivers, horns, and pro audio speakers, our Full Range series amplifiers are unparalleled.
WATTS POWER @ 4-OHMS: 2300 RMS @ 12.6V. 2800 RMS @ 13.8V. 3000 RMS @ 14.4V.
WATTS POWER @ 2-OHMS: 3800 RMS @ 12.6V. 4500 RMS @ 13.8V. 4900 RMS @ 14.4V.
WATTS POWER @ 1-OHM: 5000 RMS @ 12.6V. 6000 RMS @ 13.8V. 6400 RMS @ 14.4V
.600A Fuse.
10-500Hz Variable High.
50Hz-15KHz Variable Low
. 0-12dB Bass Boost. 45Hz, 12dB Bass Boost Frequency.
<0.7% THD.
>90dB StN Ratio.
10Hz-15KHz Frequency Response. 1-Ohm Impedance.
10-15 Operating Voltage
. 92% Efficient.
8V-0.2V Input Sensitivity
Product Information*6,000 Watts
Item Weight17 pounds
Product Dimensions16.4 x 9 x 2.8 inchesOriginChinaItem model numberPRO-FR6000.1
Apparently the 6k is even less impressive however does look a little like full bridge like brasliian
Old 09-15-2015, 07:24 PM
djscrubb's Avatar
0/11 sssss2332
Judging by the rest of the over rated amps they have I call popycock!!!!!!
Old 09-15-2015, 07:29 PM
Red Light Ear Rapist
0/11 sssss1397
i call bs, let fade clamp it
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 09-15-2015, 08:11 PM
jprophet123's Avatar
0/11 ssssss144
8500 rms @1ohm 12.6 volts with single power and ground? Hmmmmmmmm
Old 09-15-2015, 08:24 PM
RE_XXX's Avatar
0/11 sssss3181
Different style of amp. Increases rail voltage versus rail amperage. The ONLY reason why the korean/chinese amps started opting for large amounts of input was customer want.... not a need. Sure it helps, but a single run of 1/0 can carry a large amount of amperage.
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
The Following User Says Thank You to RE_XXX For This Useful Post:
cerwinvega_fan (09-16-2015)
Old 09-15-2015, 08:26 PM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2081
Feedback Score: 32 reviews
gotta linky poo for those who wanna role the dice for yolo sake?
If I were gay I would marry you.
Funny how a girl stops talking to you when you say you would rather be homeless and give her nothing than have a kid...women...
Old 09-15-2015, 08:30 PM
djscrubb's Avatar
0/11 sssss2332
http://www.amazon.com/gp/aw/d/B010NC..._1442366040867
Link is for the 6000 on amazon
Old 09-15-2015, 11:58 PM
RE_XXX's Avatar
0/11 sssss3181
Does well over 6000 rms..... pretty impressive!
Not Bad.
Old 09-16-2015, 12:26 AM
tboorn's Avatar
Fi Enthusiast
0/11 ssssss343
something seems fishy about that dyno. the input voltage on the dyno clearly reads a starting voltage of 12.20v and only drops to 12.16v during the load, yet when he pans down to the dmm (which idk why is even there) it reads 13.8v and thats what he claims the output is at. i don't understand
Fidelity--Built To Last--Team Sound Asleep
I've never, not one time, seen a gain from 45's. People think of ports as a wind tunnel. They don't work that way. They resonate. They don't produce wind. If it was a wind tunnel, 45's would be more than justified. But it isn't.
Old 09-16-2015, 12:59 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
silly, its dynamic burst
Korean Sound Quality vs. Brazillian Power???? jfoodstamp General Car Audio Discussion & Questions 44 12-09-2013 04:05 PM
Tunpo and Zenon made amps/boards Didrik Desibel General Car Audio Discussion & Questions 6 07-12-2012 11:45 PM
old school jbl bp1200.1 korean made 1350rms @ 1&2 ohm mint! ap killer usampsman Mono Amplifiers 1 03-10-2012 11:44 PM
Solid Audio f15d 1500rms at 1 ohm way underrated korean board zenon wking2 Mono Amplifiers 4 12-25-2011 09:31 AM
2 custom made "rare" svc 15' beyond audio inhumans for cheap!! BASS-HEAD 15" Subwoofers 10 12-16-2009 07:29 AM
