How are baskets tooled? - Car Audio Classifieds!
Old 09-18-2015, 08:50 PM
0/11 sssss1070
Default How are baskets tooled?
I've been wondering this for a while, there's plenty of videos on how stamped run of the mill baskets are made, but what about thick custom baskets? Seems like it's a more complicated process and would in turn drive prices up significantly, but some companies like SQ are able to keep prices extremely low so, someone please enlighten me
Old 09-18-2015, 08:59 PM
andy75's Avatar
0/11 ssssss788
Cast aluminum then machined would be my guess.
Old 09-18-2015, 09:13 PM
0/11 sssss1070
hmm so cast aluminum in the general dome shape of the basket, then the unnecessary metal would be machined out until it took its final shape?
Old 09-18-2015, 10:39 PM
0/11 ssssss298
Can be done in many ways as ive created a basket or two for sub protos.
Each one uses a mill machine mainly 5 axis table mill.
1st - machine a straight metal then use a bender and weld then grind the weld to smooth finish.
2nd - piece of aluminum fully milled to a 3d version of the basket (much more complicated)
3rd - same as first, but mill each spoke section then weld and grind together.
Sent from my ZTE ZMax using Tapatalk
Old 09-18-2015, 11:02 PM
0/11 sssss1070
no way in hell that would work for mass production...
Old 09-18-2015, 11:16 PM
0/11 ssssss245
They would be cast. The baskets I have seen don't have machined surround or spider landings. Im not saying some are not machined afterwards, prob some high end stuff is.
Think about how cheap some cast aluminum rims for cars are on ebay. Im sure there are $50 dollar rims out there and that's a whole lot more of aluminum than a basket. And wheels are definitely machined for center bore, lug holes and tire mounting surface. A basket prob cost a dollar or two to make.
Old 09-19-2015, 01:55 AM
0/11 ssssss298
You asked how they are made other then stamped right?
I just described how they make the thicker more advanced baskets.
I had to get instructions from a chinese cnc manufacturer to get it right.
For the larger production lines they stamp all baskets.
As for the type of metals used range from the 3 common types Cast Steel, Magnesium, Cast Aluminum.
Old 09-19-2015, 02:00 AM
0/11 ssssss298
5Axis Machine Cutting HELMET / DAISHIN SEIKI CORPORATION - YouTube
Take a look at this video. In a production with a true 5 axis machine it would take 5 minutes a basket then very little grinding to fix sharp edges then paint the basket to do a mass production.
Old 09-19-2015, 04:16 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
they are injection molded aluminum, no machining. you can visually see the injection points on any basket. they are dimples
www.youtube.com/watch?v=P9hffsYBiCM
Old 09-19-2015, 04:25 AM
Authorized Vendor
0/11 ssss14115
also, when someone says there tooling a new design, there referring to the mold its self.
Sundown Tooled 18" Frame : Completed sundownz (Sundown Audio) 60 11-20-2014 12:53 AM
DD 18" baskets for 15" Power hx2 baskets iamsonic Car Audio Trader (WTT) 7 07-15-2014 07:38 AM
WTB - 2 18" DC Audio Lvl6m1 baskets and/or TC Baskets. LEN671 Wanting to Buy (WTB) 3 04-14-2014 06:00 PM
WTB: TC baskets, random motors, random baskets, blown subs, etc... TeamPSI Wanting to Buy (WTB) 20 10-15-2012 09:51 PM
FS: ab hd 12" baskets. dd/aq/konaki style baskets Zooook Speaker Accessories & Parts 48 02-04-2012 12:53 PM
