2500-3000 rms at .5 ohm easy with out burning up - Car Audio Classifieds!
Old 09-20-2015, 11:45 AM
coogismoove's Avatar
1/11 ssssss228
Default 2500-3000 rms at .5 ohm easy with out burning up
i have two dual 1 ohm subs ddz tops with fi n3 motors and want a amp on each. looking for amps that will do a true 2500-3000rms at .5 ohm like it was made to but will not break the bank. i hear th ab ph4000md will do 2300 at .5 and i can get them for cheap but any other amps im open to also. i have a 270 amp singer alt and 3 deka batts.I will be running them daily and on music. Thanks for any help.
Old 09-20-2015, 01:12 PM
0/11 sssssss98
Don't waste your money on a cheap chinese amp. Buy something good that you can sell when you are done using it. Check the links:
Q1-4500D.1
Sundown Audio SCV-4000D
or maybe two of something like this
I have $300. What sub amp should I get?
Old 09-20-2015, 01:14 PM
0/11 ssssss281
If your actually looking to get 2500-3krms clamped power from being wired at .5 starting youll probably rise to around 2 ohms so an amp that does 2500-3k at 2 ohms is going to be a 5k at 1ohm amp. Something like a crescendo 5500 everest 5k something around those lines. I'd mention sundown ampere or DC but you said not break the bank
Old 09-20-2015, 02:04 PM
crownvicon26's's Avatar
0/11 sssss1882
CT Sounds 4000.1
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 09-20-2015, 02:17 PM
mega fatty
0/11 sssss6008
What about running a single 9-10k at .25 for burps or 2 for daily
Old 09-20-2015, 02:18 PM
mega fatty
0/11 sssss6008
You could even get one of those switches that is on here to switch everything
Old 09-20-2015, 04:27 PM
1/11 ssssss228
i cant afford an amp with that kind of power.
Old 09-20-2015, 04:29 PM
1/11 ssssss228
Originally Posted by crownvicon26's View Post
i see A LOT of them blown or have been repaired from being blown. thats a no go for me. thanks though.
Old 09-20-2015, 06:50 PM
0/11 sssss1067
Why not a big 2 channel amp...
ca.com traded w/ beaver1992, p3bumpin, 1phatclipse, spltuscon, profoundwill
ca.com bought from: SPY, audio_phill, ltr450racer690, huricaine
ca.com sold to: millimac247
caco: White91Formula, sleepingciv, 98AckCL23
plenty on Ebay: (Nathan7145)
Old 09-20-2015, 07:58 PM
Dragon Sounds DSA-3500 if you can find one; they were on eBay for $225 shipped for a while but I just checked and there's no listings. Same board as the Soundstream DTR3400/Massive Audio D8000.
2500-3000 RMS amp at 2ohms coogismoove Wanting to Buy (WTB) 14 05-22-2015 04:33 PM
the best amp for 2500 to 3000 rms mensah General Car Audio Discussion & Questions 47 01-03-2013 07:37 PM
2500-3000 @ 2 ohm or .5 ohm joey2010 Wanting to Buy (WTB) 4 07-26-2011 05:21 PM
15-18" sub to handle 2500-3000 rms bikerdc17 Wanting to Buy (WTB) 20 05-16-2011 07:42 AM
Custom 15" 2500-3000 rms Dunbar91 15" Subwoofers 10 04-17-2011 02:52 PM
