Drilling through sheetmetal and/or firewall - Car Audio Classifieds!
Old 09-22-2015, 09:34 PM
0/11 sssssss29
Default Drilling through sheetmetal and/or firewall
I need to drill a 2 inch hole through either the sheetmetal in my trunk or the firewall in the front of the vehicle.
What type of drill do you recommend for this task. I once saw a video of Steve Meade using a 1-2 inch bit and made the tast look so easy.
Old 09-22-2015, 09:56 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
on sheet metal, its highly advisable to use a step bit or a ratchet/hydraulic punch driver as to not shear the metal like you could possibly do using a regular hole saw.
i dont think there a step bit made as big as 2 inches, but you never know.
you could prob rent a punch driver from a hardware store, but youd need to drill a pilot hole for the draw stud.
who wants a nudel ride?
Old 09-22-2015, 10:53 PM
0/11 ssssss298
Any reason you dont want to use a bi-metal 2 in hole saw?
The step bit nudels mentioned only goes to 3/4
Sent from my ZTE ZMax using Tapatalk
Old 09-22-2015, 10:55 PM
knowledge's Avatar
0/11 sssss2548
thats what i used ^^^ a knock out ratchet punch set.
Old 09-22-2015, 11:03 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
My guess is OP is using thicker power/ground wire for such a big hole....?
I also have a set of those uni-bits. Can be had for like 20-30 bucks at most hardware stores. Lowes, Home Depot, etc.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 09-22-2015, 11:11 PM
0/11 sssssss29
Do I need to buy a power drill to attach the hole saw to?
Old 09-22-2015, 11:32 PM
0/11 ssssss298
Yes you need some sort of power drill to attach the bit.
Old 09-22-2015, 11:51 PM
0/11 ssss12531
lol might be difficult not to use one.....I'd like to see that.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 09-23-2015, 11:20 AM
knowledge's Avatar
0/11 sssss2548
no u don't i have one and all u need is a ratchet, although u can use a powered drill
Old 09-23-2015, 02:07 PM
skinnyg's Avatar
0/11 ssssss828
hole saw
Massive sheetmetal ripping flex biscuit Car Audio Videos 15 03-27-2013 11:31 PM
drilling direct leads Crazycaraudio Enclosure Discussion & Design Construction Help 3 04-03-2012 12:59 PM
drilling holes JAYARE2007MAG General Car Audio Discussion & Questions 3 10-19-2011 06:22 AM
Tapping/drilling Dunbar91 General Car Audio Discussion & Questions 8 06-21-2010 09:17 PM
drilling for motor brmcm15 (Fix My Speaker) 3 05-05-2010 11:19 AM
