Vehicle wiring schematics? Direct wire access? - Car Audio Classifieds!
Old 09-23-2015, 02:26 AM
0/11 sssss1417
Default Vehicle wiring schematics? Direct wire access?
Can anyone find me the wiring schematics for a 2015-2016 4Runner non JBL system? Please let me know. Thanks.
Team Scoshe
Team Sears
The Following User Says Thank You To stealth For This Useful Post:
stealth(Today)
Old 09-23-2015, 04:44 AM
soze1's Avatar
0/11 ssssss208
Item
Radio 12V Radio Ground Radio Ignition Radio Illumination Factory Amp Turn-on Power Antenna Left Front Speaker (+/-) Right Front Speaker (+/-) Left Rear Speaker (+/-) Right Rear Speaker (+/-) Center Channel (+/-) Subwoofer (+/-) Aux. Audio Input Left (+/-) Aux. Audio Input Right (+/-) RSE Video (+/-) RSE Audio Left (+/-) RSE Audio Right (+/-) Satellite Radio 12 Volts Satellite Radio Ground Satellite Radio Ignition Satellite Radio Antenna Satellite Audio Left (+/-) Satellite Audio Right (+/-)
Wire Color
lt. bluebrowngraygreen (parking lights); white (dimmer)N/AN/Alt. green - bluepink - yellowblack - yellowred - whiteN/Ablack - white (1); blue - pink (2)black - whitered - whitewhite - black (rear view camera)N/AN/Aredblackyellow(coaxial cable)(DIN cable)(DIN cable)
Polarity
Wire Location
radio, white 10 pin plug, pin 4radio, white 10 pin plug, pin 7radio, white 10 pin plug, pin 3radio, white 10 pin plug, pin 10; white 6 pin plug, pin 5
radio, white 10 pin plug, pins 2 - 6radio, white 10 pin plug, pins 1 - 5radio, white 6 pin plug, pins 2 - 6radio, white 6 pin plug, pins 1 - 3
amplifier in RR quarter panel, gray 10 pin plug, pins 2 - 6; 1 - 5radio, white 28 pin plug, pins 28 - 27radio, white 28 pin plug, pins 26 - 27radio, white 24 pin plug, pins 12 - 24
Satellite Radio below radio, blk 8 pin plug, pin 4Satellite Radio below radio, blk 8 pin plug, pin 8Satellite Radio below radio, blk 8 pin plug, pin 3
**tried to cpoy/paste from directechs.......didn't go as planned
The Following User Says Thank You to soze1 For This Useful Post:
stealth (09-23-2015)
Old 09-23-2015, 10:37 AM
0/11 sssss1417
Thank you very much.
Team Scoshe
Team Sears
stealth(Today)
Old 09-25-2015, 11:54 PM
0/11 sssss1417
Bump, I can't figure that out.
Team Scoshe
Team Sears
stealth(Today)
Old 09-26-2015, 12:49 AM
0/11 sssss2011
Feedback Score: 61 reviews
what are you trying to figure out?
Old 09-26-2015, 02:03 AM
0/11 sssss1417
The vehicles wiring schematics off of direct techs.
Gonna do alarm, full system, steering wheel controls, rear camera, so I'd like to save some headache.
Team Scoshe
Team Sears
stealth(Today)
Old 09-26-2015, 06:49 AM
only126db's Avatar
The One U Love 2 Hate
0/11 sssss2944
See attached PDF
The Following User Says Thank You to only126db For This Useful Post:
stealth (09-29-2015)
Source for schematics? drunkenwhippeT General Car Audio Discussion & Questions 5 07-07-2014 01:23 AM
How to run power wire under a vehicle? jheist1991 General Car Audio Discussion & Questions 10 10-19-2013 11:53 AM
RE Audio HC15 D2 w/ OEM parts + direct lead wire modification - Afforable priced BassAddictJ 15" Subwoofers 6 07-03-2013 01:41 AM
Direct lead wiring AQJEEP General Car Audio Discussion & Questions 2 01-08-2012 07:08 PM
How do i wire direct leads in parallel? Nebraskachevy General Car Audio Discussion & Questions 10 01-02-2011 08:53 PM
