Running 3 amps - Car Audio Classifieds!
Old 09-24-2015, 08:42 AM
blkmrideon22s's Avatar
0/11 ssssss487
Default Running 3 amps
I have a rainbow ipaul4.300 and 2 mb qaurt da1- 3000.1. I contacted mb qaurt and they told me the da1-3000.1 cant be strapped. What is the best options? Also I'm trying to hook up 4 subs to both amps.
1999 mitsubsihi montero sport
1 ct sounds m75.4
2 ct sounds at1400.1
1 ct sounds 6.5 pro audio comp set
Old 09-24-2015, 09:55 AM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Run pair of subs to each amp and gain match them
Old 09-24-2015, 10:07 AM
0/11 ssssss487
I should use y splitters to?
1 ct sounds m75.4
Old 09-24-2015, 12:05 PM
Splitters will work. That amp has input/output RCAs so if they are just paralleled inside you could use those. I prefer to use splitters though just to make sure the signal is exactly the same between the two amps.
Anybody running C2 Amps???? jfoodstamp General Car Audio Discussion & Questions 2 06-19-2014 06:33 PM
Coolest running amps? Wingman0121 General Car Audio Discussion & Questions 14 08-20-2012 11:38 PM
Advantages to running seperate amps? scotch03 General Car Audio Discussion & Questions 15 08-20-2012 07:20 PM
what amps are you running on lvl 18's echtenn (DC) 6 08-28-2011 04:56 PM
Running A/C to amps? LyferXB9s General Car Audio Discussion & Questions 8 08-11-2011 02:34 PM
