Having resistance issue's - Car Audio Classifieds!
Old 09-24-2015, 05:48 PM
0/11 ssssss741
Default Having resistance issue's
ok so ive got a buddy just gettin into audio.. he went and bought 2 quantum audio d4 subs. they wire down to 1 ohm just fine but when we hook them up to his kicker dxa250.1 amp they instantly jump to 2 ohms instead of being at one... has anyone ever heard of an amp "raising resistance"? any other info just ask... im no noob when it comes to wiring systems but im SUPER confused
Old 09-24-2015, 06:04 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
what process did you/he use to get the difference in load resistance?,... what are the specifics?
who wants a nudel ride?
Old 09-24-2015, 06:08 PM
0/11 ssssss741
didnt do anything... i wired the subs all parallel checked the resistance at the leads and its 1.4 on his meter which has .4 resistance between it.. now being the amp is a kicker its a 2 ohm load amp... anything ive ever checked loads on while plugged into the amp has always ohmed out fine (with amp off) but once i put the leads in the amp and check again its coming to 2.5 (.4 resistance in meter remember). i know your not supposed to exactly check ohms that way but i always do and never an issue
Old 09-24-2015, 06:09 PM
mega fatty
0/11 sssss6008
where are you measuring the 2ohms vs the 1ohm?
any chance one sub is loosing connection from a loose or fallen off connection?
07 mazdaspeed3
rd d9 @ .5ohm
Old 09-24-2015, 06:10 PM
0/11 ssssss741
the 2 ohm is hooked into the speaker terms and 1 ohm is leads all together outside of box since its being weird...
Old 09-24-2015, 06:13 PM
mega fatty
0/11 sssss6008
so if you take it off the amp again will it read 1ohm?
and the second you touch it to the amp it reads 2ohm?
07 mazdaspeed3
rd d9 @ .5ohm
Old 09-24-2015, 06:18 PM
0/11 ssssss741
correct sir... he has 2 amps and both do the exact same thing which is what has me thrown off..
Old 09-24-2015, 07:38 PM
You can't measure resistance (or impedance) with the speakers connected to the amp like that, as you'll be measuring the speaker's DCR along with any components connected in parallel with the speaker terminals inside of the amp.
SINTORMAN (09-24-2015)
Old 09-24-2015, 09:55 PM
mega fatty
0/11 sssss6008
If Anything was in parallel it would divide the resistance more not less
Are you sure the amps outputs are in parallel and you are not just measuring one sub on each set of outputs?
Old 09-24-2015, 11:20 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Id just run it. Clamp it and see what you are gettin and go from there.
01 Volkswagen Golf 2 door
Kenwood ddx470
Same power, different resistance? swizard98 General Car Audio Discussion & Questions 14 10-09-2014 08:34 AM
Pioneer DEH-880PRS w/ pico fuse issue and flex ribbon issue groundpound4200 Broken & Non-working equipment 3 04-15-2013 06:58 AM
Setting gains, Impedence, or Resistance sidewalk General Car Audio Discussion & Questions 6 03-22-2011 01:20 AM
internal resistance ? 9515ROB General Car Audio Discussion & Questions 0 09-26-2010 10:13 AM
[COMPLEX] Resistance vs Impedence danteBirosel Tutorials & Quick References 0 11-12-2008 01:41 PM
