pass though - Car Audio Classifieds!
Old 09-25-2015, 04:55 PM
blkmrideon22s's Avatar
0/11 ssssss487
Default pass though
what is a pass though inputs ? i know rockford fosgate has it.
1999 mitsubsihi montero sport
1 ct sounds m75.4
2 ct sounds at1400.1
1 ct sounds 6.5 pro audio comp set
Old 09-25-2015, 05:00 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
The RCA signal that goes in to amp simply gets transferred to the output channels without having to use RCA splitter or 'Y' cables.
Unless I don't understand the question.
The Following User Says Thank You to craiggus365 For This Useful Post:
blkmrideon22s (09-25-2015)
Old 09-25-2015, 05:36 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
https://answers.yahoo.com/question/i...5163405AAkHebY
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
The Following User Says Thank You to Boomintahoe For This Useful Post:
Low Pass (lpf) BMFM35 General Car Audio Discussion & Questions 1 07-02-2013 01:53 PM
Band pass 1LOUDYUKON Enclosure Discussion & Design Construction Help 9 06-16-2013 06:48 AM
High pass, low pass help ImpalaOnDubs General Car Audio Discussion & Questions 10 06-28-2012 03:58 PM
What's pass thru? davidrforbus General Car Audio Discussion & Questions 10 08-29-2010 10:30 AM
Pass Filters mattinthebox General Car Audio Discussion & Questions 1 06-23-2009 11:55 AM
