Need Coil help please - Car Audio Classifieds!
Old 09-30-2015, 10:40 PM
0/11 ssssss437
Default Need Coil help please
So what would be the maximum coil Id and od I could use on a gap that is 2.9/3.3 ? I have a coil but think it's too tight at 3.284 od
Old 09-30-2015, 11:00 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
it depends on who's building it. some run safer then others as tight tolerances are exactly that. your coil will not work. way too tight, about the thickness of card stock on the OD. myself, I prefer a bit over .125 on the od atleast (per side) this allows for wobble in the moving assembly and air flow across the OD of the coil for cooling/decreased noise/back pressure. I prefer around the same on the ID but keep in mind too loose on the pole will murder thermal capacity
Old 09-30-2015, 11:24 PM
0/11 sssss1085
Feedback Score: 23 reviews
I've used coils with a 3.264 OD with those Cascade steels before with good results.
Old 09-30-2015, 11:50 PM
0/11 ssssss437
What is your thoughts on this one? All out spl 2k each clamped.
3" Dual 1 Ohm Voice Coil 4 Layers VC140910 | eBay
Old 10-01-2015, 01:21 AM
0/11 sssss1085
It'll work.
Spl coil vs stock coil question (for sa series) newarkbeast973 (Sundown Audio) 2 11-17-2011 12:09 AM
10" sub with 4 ohm single coil - helps if you have a DMM to meter the coil for me. nismos14 Wanting to Buy (WTB) 8 09-05-2011 01:18 PM
Elevation EXE motor and a 3" Round aluminum TC coil, D.5, coil can easily handle 2k R Novicaine Car Audio Packages 7 05-04-2011 09:59 PM
FS:GIANT 4" coil. real big coil. Violence* Speaker Accessories & Parts 8 03-10-2011 10:50 AM
