Amp on Stock HU - Car Audio Classifieds!
Old 10-02-2015, 01:59 AM
0/11 ssssss857
Default Amp on Stock HU
Hey guys im not a complete noob on installs but i am stumbling over what to do here. I just bought my fiancee a 2013 fusion, she doesn't want me to mess with the stock dash and steering-wheel controls but wants an 8 in the trunk.
So I picked out the amp and am building the 8 as soon as the motors arrive. I am looking at the http://www.ebay.com/itm/Pac-SNI50A-A...-/131611302213 to tap into the rear speaker wires to have the pair of RCAs for the mono amp. Now obviously i connect RCA from this to the amp. I connect + to the battery and - to a goo ground source. Now for the remote wire i am assuming best thing to do is find a fuse opening that is key on only?
If thats the case, does that require a fuse or how should i attach it to that location? May seem dumb i just need to do it right.
Thanks
Old 10-02-2015, 07:22 AM
0/11 ssssss292
I like to use the actual ignition wire with a fuse inline for remote, but you can find a fuse that turns on with ignition as well. I always fuse them though.
Old 10-02-2015, 08:51 AM
0/11 sssss1528
I used the exact same thing on my 2013 fusion. Worked fine
Old 10-02-2015, 09:16 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Thanks
Maybe something like this?
5 x Mini ATM Fuse Adapter Tap Dual Circuit Adapter Holder for Car Truck Auto | eBay
Or this?
http://www.ebay.com/itm/5x-10A-Add-C...item54167a88e2
My game is legit,
Old 10-02-2015, 09:50 AM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2081
Feedback Score: 32 reviews
Are there any switched lighter outlets in the car?
If I were gay I would marry you.
Funny how a girl stops talking to you when you say you would rather be homeless and give her nothing than have a kid...women...
Old 10-02-2015, 05:49 PM
0/11 ssssss857
Havent looked yet, Im not sure. I know there are three lighter spots in that damn car. I will tap around with the DMM. Thanks guys
Old 10-02-2015, 05:59 PM
0/11 ssssss857
Now for the next dumb question, how do these work? I see what would go into the fuse box, but why is there two fuse openings on them and does the wire act as the remote to the amp?
Edit: Im kind of understanding it that the top fuse is the fuse for the new remote turn on for the amp and the bottom fuse hole is the stock fuse that was removed. But you are now putting a larger draw on that fuse so should i increase it? And how do i know what size fuse (amp wise) to put on the remote turn on line?
Thanks
Old 10-02-2015, 06:26 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7099
Eww don't use non-electronic LOC's. They are junk. I tried 3 different ones on my stock unit and they all clipped much sooner (well, they actually clipped...and my powered LOC's don't)
Get a PDLC21 for like $35 shipped.
I have one, and it's metal-case clone, the cache cloc+d on my stock unit. One goes directly to sub amp and the other goes to my crossover, which splits one RCA into a mid and high output for my 4 channel.
It has a line driver built in so it will give you proper RCA voltage as well.
I just put one of these pdlc21's on a 2v sony unit just as the line driver function and it made a huge difference.
The unit itself has auto detecting turn on, so you don't need to run a remote wire.
https://www.youtube.com/watch?v=EE7RlcOJ5-Q
These are the exact same units, one is simply metal and has the lights on top.
PAC PDLC21 2-Channel Intelligent Digital Line Output Converter - Walmart.com
And on top of everything I've already mentioned, the unit comes with a built in in-line fuse holder and 2a fuse, so all you have to do is find a power source for it. (and considering it only draws 2a, you can use any thin wire that is close)
team graham
Old 10-02-2015, 07:25 PM
socalxj's Avatar
0/11 sssss2371
Why not use a toggle switch? you have to remember to turn it off
Old 10-03-2015, 07:48 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Now that's old school!
remember doing that before amps had remote wires in place.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Buying B stock amp chevy454 General Car Audio Discussion & Questions 10 04-26-2015 01:00 AM
Stock hu. Cache clockd. Sub amp. Maybe cross/highs amp graham General Car Audio Discussion & Questions 0 03-01-2013 12:14 PM
Dd m2b...perfect street stock amp jws84_02 Mono Amplifiers 16 02-22-2013 02:42 PM
Would after market speaker will work ok with stock amp?? nysid2007 General Car Audio Discussion & Questions 3 06-14-2012 02:44 AM
Biggest Amp I can get with stock electrical and ONE XS 3100 TwistedMinds (Sundown Audio) 14 09-11-2010 05:47 PM
