why is my "2600" watt amp quiter then my 1000watt - Car Audio Classifieds!
Old 10-04-2015, 10:57 AM
0/11 ssssss313
Default why is my "2600" watt amp quiter then my 1000watt
i have a hifonics x14 2600 an a old kicker zx750.1 an it seems like the kicker is noticeably louder obviously hifonics isn't as good of a brand but shouldn't it be louder id like some intelligent feed back
Old 10-04-2015, 11:23 AM
andy75's Avatar
0/11 ssssss788
Gains properly set?
Old 10-04-2015, 11:56 AM
mbdblue's Avatar
0/11 ssssss744
Feedback Score: 21 reviews
at what ohm load?
Life's short, Play loud================================================== ==
Old 10-04-2015, 12:04 PM
Turn it up's Avatar
0/11 sssss1933
if both amps are at 2 ohm kicker>hifonics
Old 10-04-2015, 12:34 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
kx750.1 = [email protected]
h/f x14 x2600.1 = [email protected]
something is wrong. most likely in the dial settings the 2600.1 has
maniac, can you take a pic of your settings on the h/f?
who wants a nudel ride?
Old 10-04-2015, 02:42 PM
0/11 ssssss313
both amps were wired @1ohm the kicker handled it pretty good unless you cranked it but the lows were louder on the kicker
Old 10-04-2015, 02:55 PM
0/11 ssssss313
http://4gp.tw/ba3k/1443988345102.jpg
Old 10-04-2015, 02:58 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7099
Do you have a volt meter hooked up?
Also, you are spot on with the quotes around the wattage...hifonics should put that on the box. "2600" w rms @ 1 ohm
team graham
Old 10-04-2015, 03:37 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
Lows better on the kicker? I can only assume because the kicker doesn't have a subsonic and the Hifi does. But overall the hifi would be louder properly set.
Current Build:
#60sHereIcome
Old 10-04-2015, 03:46 PM
mega fatty
0/11 sssss6008
you have your low pass filter (lpf) set for 30hz
so its only putting out below 30 and above 15
07 mazdaspeed3
rd d9 @ .5ohm
[SOLD LOCAL]FS: Konaki "2400 watt" Mono amp BlackWaterOp Mono Amplifiers 6 07-25-2009 11:39 PM
