Volt meter - Car Audio Classifieds!
Old 10-13-2015, 09:18 AM
blkmrideon22s's Avatar
0/11 ssssss487
Default Volt meter
Why do people use more then one volt meter in there rides? I thought bout buy 2 stinger volt meters to see the voltage of my alt and my amp.
1999 mitsubsihi montero sport
1 ct sounds m75.4
2 ct sounds at1400.1
1 ct sounds 6.5 pro audio comp set
Old 10-13-2015, 09:31 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
All though pricey, grab a lascar 24m. You can read both on one gorgeous and deadly accurate display. And make it whatever you want via computer upload
Old 10-13-2015, 09:32 AM
massivespl's Avatar
0/11 sssss8409
I have two volt meters. 1 at each 8k amp
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-13-2015, 10:30 AM
Lock up your daughters!
0/11 sssss1342
I have two because I'm running isolated electrical systems.
My Silverado:
Old 10-13-2015, 11:42 AM
Beatdown337's Avatar
0/11 sssss1535
Not to thread jack, but just curious to know how you guys have your voltmeters connected. I mean do you have it crammed into the power wire terminal for your bass amp? Or is there a better way?
Old 10-13-2015, 12:21 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
I put mine in the amp terminals and run my second one off my vehicle hot wire just to make sure I'm not killing my electrical on my ride as well
Old 10-13-2015, 04:55 PM
I have one connected to the amp distribution block to get amp voltage and one one my "factory" wiring behind the dash, just like b-shot. The way they are wired, and the fact that I only have batteries in the back (nothing underhood), if voltage suddenly drops on one meter instead of the other I can figure out which fuse has blown or if there's an alternator problem.
Old 10-13-2015, 04:58 PM
Authorized Vendor
0/11 ssss14115
just noticed your in Boone
Old 10-13-2015, 05:21 PM
0/11 ssssss487
yes i am from boone nc
1 ct sounds m75.4
Old 10-17-2015, 06:01 AM
0/11 sssss5305
Spend your $$$ on HO alts and batts.......gauge won't really matter then...
volt meter gibsons General Car Audio Discussion & Questions 16 12-17-2014 07:28 AM
16 volt volt meter? what do you use? lilsoccersully General Car Audio Discussion & Questions 15 07-06-2013 10:39 PM
Looking for a good volt meter and temperature meter.NOT STINGER!!! fosgatefeind General Car Audio Discussion & Questions 42 12-10-2012 03:52 PM
volt meter.... JAYARE2007MAG General Car Audio Discussion & Questions 28 09-30-2011 09:51 PM
[FOUND] Stinger volt meter, or any other digital volt meter... andrewtexas123 Wanting to Buy (WTB) 8 09-20-2010 10:50 PM
