Questions on sealing off trunk. - Car Audio Classifieds!
Old 10-18-2015, 08:35 PM
newarkbeast973's Avatar
0/11 sssss7810
Default Questions on sealing off trunk.
So, I'm thinking of a rebuild of my sub stage. I'm looking to seal of the trunk and also opening up the center arm rest for when the seats aren't folded down.
So my questions are.
1. Does it matter that I have a regular ported enclosure and not an external ported enclosure?
2. Is there a distance that the enclosure have to be away from the back of the seat?
3. How do you make sure that the enclosure is and stays attached to the walls used to seal it off? And also how do you secure the walls to the rear of the seats?
Thanks
New build coming soon!!
Old 10-18-2015, 08:55 PM
0/11 sssss3526
What is the normal resonance of your car? I lost on the term lab by sealing off
Old 10-18-2015, 10:09 PM
0/11 sssss7810
Honestly, I have no clue. I feel that a lot of my bass gets trapped in the trunk. Not competing so not concerned with numbers. Just would like to feel more of the bass.
Old 10-18-2015, 10:14 PM
0/11 sssss3526
So from what I've seen and been around meter wise, external port seems to meter higher. I've also seen that the farther back the box is set, tends to meter higher.
What car/Subs/amp?
Old 10-19-2015, 01:33 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
treatment of the trunk itself is probably the most important part too a loud trunk. I think the difference between internal vs external is not as much as some think but more so install dependent.
But to feel it more I'd probably just seal it off and call it a day. IMO spray foam and fiberglass is your best bet.
Current Build:
#60sHereIcome
Old 10-19-2015, 02:11 AM
0/11 sssss3526
Sprayfoam is easy to do. I just treat the areas I'll foam with painters tape and fill gaps. Down the line, you don't want to be trying to get that foam off of carpet etc. Its a pain in the ass.. The tape will pull right up.
Old 10-19-2015, 02:18 AM
doug118's Avatar
0/11 sssss4674
Did you try firing the subs back instead of forward? My truck car was much louder to the ear when firing back vs forward. I know it's not the same for all cars but it's worth a try
Old 10-19-2015, 02:46 PM
0/11 sssss3526
My trunk was loudest subs forward, port passenger side. No sealing off.
I think its overstated that sealing off is the loudest. Its almost completely car dependent
Old 10-19-2015, 07:25 PM
0/11 sssss7810
The car is a 2006 Nissan Altima. The equipment is is 2-12" DC XL's on a DC5k @ .5 ohms. I've faced the subs back and forward. My trunk has layers of deadener all over! The pressure feels like the trunk will pop off at times! I assume that if I seal off the trunk, all that pressure (bass) will come in the cabin. Or am I mistaking the concept?
Thanks
Old 10-19-2015, 08:10 PM
0/11 sssssss63
What is the goal you are trying to achieve?Soome times sealing off can lose some SPL but from my experience that is usually from people actually hearing the distortion and having to decrease the gains acordingly etc.
With the equipment you have listed I wouldn't hesitate to seal off the trunk with the subs firing into the cabin and doing a center port or up through the deck.As for where to port I'd plan on up if you tend to use the seat quite a bit because of the pressur that will be trapped between the seats.Another trick to letting sound through is to space the seat latches out for daily use and open up the armrest area
If you had lesser quality gear I'd honestly tell you to keep it firing to the rear etc but the higher up the ladder you go the better the results I've seen from firing into the cabin.
Also if SPL was the only goal and you where a die hard DB guy I'd recomend to try absolutely everything and to look at every similar car that you could before deciding but IMHO 2 DC XL's pounding inside the cabin on a 5K has a visual impact that to 98% of the people out there would probably overcome the possibility of loosing a db or so that could possibly come from other box placements
Sealing trunk. 04'-05 XXXs cloud77 General Car Audio Discussion & Questions 0 05-13-2015 06:44 PM
Trunk setup. subs facing forward sealing trunk off? Inferno3436 General Car Audio Discussion & Questions 38 05-13-2014 09:01 AM
Concern about sealing off trunk iKidwell General Car Audio Discussion & Questions 9 05-08-2014 10:15 AM
sealing off trunk gbo559 General Car Audio Discussion & Questions 50 12-30-2009 10:21 PM
Sealing off the trunk? mazda6i07 Enclosure Discussion & Design Construction Help 51 10-23-2008 07:07 PM
