Kenwood problem, help - Car Audio Classifieds!
Old 10-20-2015, 12:35 AM
0/11 ssssss225
Default Kenwood problem, help
Just installed a new radio. Kenwood x599. Everything works except the signal to the amp. Checked all the rcas. They are fine as I had had a radio in before this one and everything worked then. Sky high rcas and a pac lc1.checked all the setting in the radio.. I'm stumped.
Old 10-20-2015, 01:39 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7099
RCA signal to the amp?
Take LC-1 out and try straight RCA.
Try the RCA's one by one (only one plugged in) maybe a bad RCA. Try all different combinations. Could be something bad on the amp OR the unit. If they aren't tiffany style, they DO get messed up once in a while if you aren't very careful.
team graham
Old 10-20-2015, 09:46 AM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Turn on the subwoofer output. Its turned off on the hu or the subwoofer level is turned way down into the negatives
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 10-20-2015, 10:25 AM
0/11 ssssss225
[PDF[/PDF]
It was not that as I already try ed all that..
Old 10-20-2015, 10:29 AM
Team SPL Farms
0/11 sssss5000
Bypass the lc-1 to eliminate it as well
Kenwood ddx470
Old 10-20-2015, 10:59 AM
0/11 ssssss225
Well found it out. The rca jumper from the radio to the pac is bad... I'd why it is. No pnches or bad jacket. But I used a extra pair I had and try ed that. I first ran it from the radio straight to the amp and it worked . So it had to be in the old rcas or pac. Used the old rcas radio to pack. And it worked.
kenwood kdc-x891 usb/cd/mp3/ and Kenwood ipod adapter $110 gentlejax2 Head Units, Processors & EQs 5 07-14-2012 07:01 PM
[NLFS]Kenwood KDC-X794 Head unit and Kenwood Sirius tuner/adapters duece212 Head Units, Processors & EQs 4 06-07-2010 11:15 PM
problem with kenwood excelon kdc 692 kingmade08 General Car Audio Discussion & Questions 5 05-21-2010 12:49 PM
problem with 3kwp [Problem Solved] jizazz12 (Crescendo) 10 04-30-2010 06:46 AM
Kenwood vz907 problem heydude348 General Car Audio Discussion & Questions 0 09-16-2009 04:21 PM
