anything i should know when i upgrade to a 370 alt - Car Audio Classifieds!
Old 10-20-2015, 02:59 AM
0/11 ssssss313
Default anything i should know when i upgrade to a 370 alt
im more concerned about not burning my car down is there anything important i should know when i upgrade to the new alt?
also i would like to know if theres a cheaper alt out there that will do 350+ besides dc (kinda expensive) 2003 pontiac aztek
Old 10-20-2015, 04:19 AM
KickinBlazer's Avatar
0/11 sssss1122
as far as i know mechman and DC and ohio gen have the biggest ones...and make sure all connections are good and solid and ground the alt directly to the battery and of course big 4
if its to loud your to old!
Old 10-20-2015, 06:04 AM
Use a good belt. Cheap-o ones will slip on you. Make sure you've got a voltmeter to monitor voltage.
As for not burning things down just make sure you fuse appropriately.
Old 10-20-2015, 08:22 AM
0/11 ssssss281
There is also singer but there all around the same price
Old 10-20-2015, 08:24 AM
massivespl's Avatar
0/11 sssss8409
Excessive amperage or Ohio generators... I'm pretty sure I'm going to be switching over to Ohio after talking to Tom this weekend. He knows his shit!!!
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-20-2015, 08:41 AM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Check to see what they do at idle cause a 350 amp alt at 2k rpm and only 100 amp at idle will suck for daily.
Old 10-20-2015, 08:47 AM
massivespl's Avatar
0/11 sssss8409
Ohio alts has a $50,000 testing machine that comes with a real print out. No other company has that machine according to Tom. His alts do the best idle on the market
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-20-2015, 08:48 AM
0/11 ssssss313
this is the one im looking at https://www.dcpowerinc.com/fit/Ponti...b-vehicle_fits
Old 10-20-2015, 08:52 AM
djscrubb's Avatar
0/11 sssss2332
I don't know I got a print out from one of my cheap ebay alternators............seemed legit as well as the 2 275 I bought tested different.
Ohio is legit though would company been around for a while. The 275 I have does 300 or so hot pretty impressed
Old 10-20-2015, 08:58 AM
massivespl's Avatar
0/11 sssss8409
Got link to alts you bought?
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Upgrade Alt? theFiverMan General Car Audio Discussion & Questions 5 05-07-2014 09:50 AM
Upgrade my alt eddiemoua94 General Car Audio Discussion & Questions 4 01-10-2011 07:53 PM
Need advise on alt upgrade masterbarber General Car Audio Discussion & Questions 4 09-26-2010 06:04 PM
06 commander alt upgrade? kapone D.O.A General Car Audio Discussion & Questions 2 12-04-2009 05:18 PM
