B2 zero.7 or larger amp? - Car Audio Classifieds!
Old 02-18-2016, 09:58 AM
crownvicon26's's Avatar
0/11 sssss1882
Default B2 zero.7 or larger amp?
Would a B2 zero.7 be a good match for 3 zv3 15 's @ .33 nominal or should I get a larger amp?
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 02-18-2016, 08:43 PM
0/11 sssss1882
Up top
Taramps 8k
2 Zv.3 15's
Old 02-19-2016, 12:03 AM
0/11 sssss3526
My buddy ran 3 zv3 15s on 2 bc5500s and it was pretty brutal. 155+ below window line. Iirc each amp was strapped at .66 (1.33)
The Following User Says Thank You to kr-15 For This Useful Post:
crownvicon26's (02-19-2016)
Old 02-19-2016, 04:12 AM
0/11 sssss1882
So I need 10k? That amp does around 7-7.5k
Taramps 8k
2 Zv.3 15's
Old 02-19-2016, 04:31 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
i think it would do pretty good if wired a bit low .5 ish. the lower power is semi compensated by the cone area though after rise you may want more power. id run the zero 7 if you already have it and see how it does then upgrade later on if not happy
Old 02-19-2016, 05:50 AM
0/11 ssssss416
7K is a good bit of power, especially if you can wire to low to really get that 7k from it. On a burp I'm sure the z3's can handle more, but for daily on music I wouldn't be surprised if that does very well for them.
The Following User Says Thank You to T3mpest For This Useful Post:
Old 02-19-2016, 06:17 AM
0/11 sssss1381
i ran a ampere 7500 at .46 on 3 dc xlm2 15s and they loved it. clamped 7200 watts after rise. 152.1 legal in a avalanche blow through
2014 Chevy Silverado lifted 9 inches
Fuel 24x12s and 35s
Nations dual alternator bracket dc power 370 alt, 3 Fi SP4v2 18s,big ass 16v stable amp , JY 45ah 16v Lithium, JY ofc 1/0, fiberglass doors, 3 krome ka10s 3 mclaren mlt8 tweeters. 2 soundigital sd2000.1 evos on mids mclaren 600.2 on tweeters. Pioneer 80prs
The Following User Says Thank You to yotabass1 For This Useful Post:
Old 02-19-2016, 06:19 AM
0/11 sssss1882
Thanks guys. Yeah I already have it. Will be wired to .33.
Taramps 8k
2 Zv.3 15's
Old 02-19-2016, 09:10 AM
0/11 sssss3526
The b2 amps respond pretty well to low impedance right? If you rise to ~1ohm you will be clamping well over rated. It will be more than enough for daily
Old 02-19-2016, 10:27 AM
0/11 sssss1882
Yeah. I think it did like 7k at .8 reactive @13v on an amp dyno.
Taramps 8k
2 Zv.3 15's
Wtt for larger amp. 1loudmonte Car Audio Trader (WTT) 3 12-02-2015 08:17 AM
larger amp cheebs General Car Audio Discussion & Questions 2 01-02-2014 10:59 PM
Popcorn 2500 for larger amp doug118 Car Audio Trader (WTT) 1 12-25-2013 09:10 PM
WTT 4k amp/alt/more for larger amp. D_Roc Car Audio Trader (WTT) 20 11-23-2011 05:08 PM
Looking for 3k or larger rms amp russhay78 Wanting to Buy (WTB) 10 04-27-2009 10:02 PM
