strapping amps with no master/slave switch - Car Audio Classifieds!
Old 02-20-2016, 01:49 AM
williamhung's Avatar
0/11 ssssss536
Default strapping amps with no master/slave switch
What up fellas! My question today is about strapping two caraudiobargain.com cab-1600.1's. They are strappable, but the manual is very vague to say the least. It shows how to put the rca jacks for bridged in and out and connecting the remote to the "master", but not how to hook up the speaker wires or what is suppose to be done as far as all the adjustment nobs on the slave. Since it has no slave/master switch, am I suppose to leave all the settings on the slave at zero and the master Will control all? Also is it suppose to be positive of master output to positive of subs and positive of slave to negative of subs with a jumper wire between both negatives on the amp? Thanks in advance guys!
2 Stereo Integrity HT-15's
1 Stereo Integrity HST-15
Old 02-20-2016, 03:08 AM
0/11 ssssss536
This is what my amp looks like
Old 02-20-2016, 07:53 AM
massivespl's Avatar
0/11 sssss8409
Just gain match. Strapping blows
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
The Following User Says Thank You to massivespl For This Useful Post:
lunchbox (02-23-2016)
Old 02-20-2016, 09:11 AM
Is there a manual for the amp? The way you describe is exactly how mine are strapped.
Old 02-20-2016, 09:53 AM
0/11 ssssss536
Yes there is but this is all it has to show for strapping...no actual write up on it just a pic
Old 02-20-2016, 09:55 AM
0/11 ssssss536
Here it is
Old 02-20-2016, 09:58 AM
0/11 ssssss536
Do you think that's best?...also I sent you a private message about another subject
Old 02-21-2016, 07:58 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Yup...gain match would be the best way.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 02-21-2016, 10:07 AM
Beatdown337's Avatar
0/11 sssss1535
In my experience it's always been,
Speaker wire positive to positive on master
Speaker wire negative to positive on slave
Jumper wire between negatives
One rca from slave out on master going to slave in Slave
Old 02-23-2016, 02:13 AM
0/11 ssssss536
Followed this rule last night and it was a success. Was a little nervous cause I already blew one letting the speaker wires touch at full tilt, (my own dumb ass fault) but it all worked out. I actually have them running at 1om strapped so both amps are seeing a .05 load and holy crap do these suckers bang! don't even have them turned up more than half way and they are staying cool. I just finished putting in a odessey group 31 under the hood all 1/0 gauge with a stinger 500 amp battery relay, then ran a 2/0 welding wire to the amps under the seat. Only thing is I cant turn it up really much because I keep popping my 300 amp breaker under the hood. Ordered a 500 amp anl fuse last night so it will be here Friday. then I can play a little more with it. all in all very pleased with caraudiobargain.com amps. they have yet to disappoint. will try to do some clamping in the future.
can i run this master/slave setup on a single sub? Fitseries3 General Car Audio Discussion & Questions 6 12-28-2012 01:09 PM
master/slave function without strapping? Dbmonster General Car Audio Discussion & Questions 2 09-20-2010 11:28 PM
why doesnt my amp work unless hooked up in master to another in slave numba1system General Car Audio Discussion & Questions 2 01-07-2010 01:01 AM
master slave?? tankglh21 General Car Audio Discussion & Questions 58 07-29-2009 02:31 AM
