what would you guys do, clamp 4k? - Car Audio Classifieds!
Old 02-22-2016, 05:59 PM
0/11 ssssss117
Default what would you guys do, clamp 4k?
So i have 2 12 dss ethos dual 1 subs. Ive been told they can take over 2k so i want to push a true 2000 rms to each one. I have the choices of wiring to either .25, 1, or 4 Or i can wire each sub seperate at .5 2 ohms, etc So im not not at all what my box rise is.
Here are my choices on what i have thought to do and im trying to clamp close to 4k. I guess i dont want to spend over $1000 on a 5k amp and not even see a true 3k.
Setup 1: 2 2-3k amps wired at .5 ohms to each sub
Setup 2: 1 5-6k amp wired at 1 ohm for both subs.
My electrical: singer 270A large case alt, 3 Xs d3100, and a stock 80ah agm.
What would you do and why? Will this be enough electrical to hold 12.8 or mid 12s full tilt?
Old 02-22-2016, 06:03 PM
Red Light Ear Rapist
0/11 sssss1397
Math for 4k clamped, what your car draws for its self is a different story
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 02-22-2016, 06:07 PM
0/11 sssss1397
And just buy a quality amp, sundown, ampere, crossfire, etc and you get the wattage you pay for
4 Crossfire v4 18s
Old 02-22-2016, 06:15 PM
So Low's Avatar
0/11 sssss1258
Sundown SCV 6k for a grand on db-r
DD M4A f/s in the mono amps section
Taramps 10k?
The Following User Says Thank You to So Low For This Useful Post:
B-Shot (02-22-2016)
Old 02-22-2016, 06:58 PM
mega fatty
0/11 sssss6008
I would just get a 5-6k
But you could get more power with 2 3ks at .5
Old 02-22-2016, 07:14 PM
0/11 ssssss117
see its hard because i can get 2 ampere 2k for like 600. or any other decent 2-3k for 800 for both. a good solid 5-6k is over 1000 brand new and i may only get 3k out of it at most which is the hard part.
Old 02-22-2016, 07:20 PM
massivespl's Avatar
0/11 sssss8409
Two fsd2600 amps.. One for each woofer at .5ohm = $660
http://audio-legion.myshopify.com/pr...lock-amplifier
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 02-22-2016, 07:21 PM
So Low's Avatar
0/11 sssss1258
So you would have to go refurb or go Brazilian.
There are execution audio 1500.1s for $190 each on ebay
Old 02-22-2016, 07:36 PM
0/11 ssssss117
FSD Audio FZ2600D 2600-Watt Class-D Monoblock Amplifier – Audio Legion
ive thought about that. But not too sure i want to do that. I know twisted sounds is coming out with a 5k that does over 6300 rms and its gonna be a crazy price. I want something now tho lol. I think if i got those 2 fsd i could clamp 2k out of each wiring at .5
Old 02-22-2016, 07:39 PM
mega fatty
0/11 sssss6008
Are you chasing numbers on the meter?
Clamped and just daily listening are totally different things
Plus the difference between 3k and 4k is likely under 1db.
Rise is a totally natural thing if you have high rise wire low or build more efficiently
Chevy HHR guys? DD guys? Shadn General Car Audio Discussion & Questions 9 10-10-2015 08:35 PM
Anybody use HF clamp? dirt101 General Car Audio Discussion & Questions 5 09-01-2013 10:36 AM
Good AC Clamp? alonzoub General Car Audio Discussion & Questions 6 07-08-2011 06:51 PM
us good guys =1 the bad guys =0 THANK YOU OHIO!! kn0wledge000 Uncensored Off Topic 7 06-22-2011 04:27 PM
