DB Drive CAP5. - Car Audio Classifieds!
Old 02-24-2016, 02:39 PM
0/11 sssssss10
Default DB Drive CAP5.
Hello,
I've just bought the 5 Farad digital capacitor DBCAP5 from DB Drive.
The user manual, as expected, barely explains how to connect it.
Two questions:
a) As the rest of the traditional caps, this capacitor must be first charged with a resistor prior to make the power connections?
Nothing of that is mentioned on the user manual, not sure if can be connected as any other component or must be slowly charged, like the most of the current caps on the market.
b) The installation diagram shows that a fuse must be placed between the positive output of the cap and the amp input, is this really necessary?
My previous capacitor was wired directly to my amp without an inline fuse without issues for years.
Thanks in advance.
Old 02-24-2016, 02:59 PM
mega fatty
0/11 sssss6008
You should slow charge it
You should put a fuse if it has to go more than 18" to the amp or through metal
If that wire shorts it could potentially cause a fire with no fuse
A lot of people don't fuse there if it is short and un obstructed
The Following User Says Thank You to tymoto21 For This Useful Post:
segovia (02-24-2016)
DB Drive Husker 10" Subwoofers 3 04-27-2015 10:29 PM
Over drive noknok Wiring, Electrical & Other Installation Equipment 13 04-22-2011 04:54 PM
4wheel drive vs 2 wheel drive fuel economy? F3M4 General Automotive Chat 8 01-29-2010 04:04 PM
DB Drive sruggles1976 (Fix My Speaker) 1 07-22-2009 11:18 AM
