Box building calculator... what do yall use? - Car Audio Classifieds!
Old 03-03-2016, 12:19 PM
0/11 sssssss22
Default Box building calculator... what do yall use?
What are you guys using to calculate port displacement etc.
Old 03-03-2016, 12:41 PM
Red Light Ear Rapist
0/11 sssss1397
Torres for quick stuff
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 03-03-2016, 01:17 PM
BassBox6 or WinISD for modeling; pen and paper for dimensional/volume stuff.
Old 03-03-2016, 01:28 PM
0/11 sssssss22
I guess I should have clarified. I wanna be able to use my phone. Can I use any of those on my phone?
Old 03-03-2016, 01:51 PM
0/11 sssss1397
Xplict car audio had an android phone app. I don't use it though.
4 Crossfire v4 18s
Old 03-03-2016, 02:50 PM
209native's Avatar
0/11 sssss1975
the12volt.com is what I use
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 03-03-2016, 03:06 PM
0/11 sssssss22
I didn't know about the explicit audio app. I'll try that out tonight.
I've tried 12volt.com but there was something I didn't like about it. Can't remember. Ill give it a try again. Might have been user error lol
Old 03-03-2016, 04:22 PM
So Low's Avatar
0/11 sssss1258
Are you doing that many that you need to do the calcs on your phone? Or do you not have access to a computer
If I'm building something I will always model it in SolidWorks, and check volumes on there. Even on weird shapes its accurate to like three decimal places. Plus you can pull maximum and minimum dimensions in X,Y,and Z directions to check things like resonances and compression, plug in pressure values to see strain levels on bigger unbraced panels, and even send parameters to CNC machines or 3D printers. Probably the best business expense you can have if you are in the industry. I've been out of the business for like 5 years and I still pay my license fees just because I've become so hooked on its versatility.
If you need someone to put a design together for you hit me up, no charge mate
Old 03-03-2016, 04:31 PM
0/11 sssssss22
No its just for personal use. I don't really have access to a pc. Im just being picky cause I got a link from someone on smd a couple years ago. It was a really cool website. It's actually how I learned to build boxes but I lost the bookmark when I got a new phone it was a weird address the only thing I remember was it had 'bit' in the address. Thanks for the help tho
I was playing with the xplict calculator. Does anyone know how accurate it is?
Old 03-03-2016, 04:39 PM
0/11 sssssss22
The website I'm speaking of showed the formula for finding the cu ft of wld (which is quite simple) then I explained how to -displacement. Then you plug in the cu ft, the port area and tuning frequently. Then it would give you the port length and I believe gross cu ft. Idk if anyone else has use it but i thought it was pretty awesome
Box Calculator colorblind83 General Car Audio Discussion & Questions 1 05-03-2015 07:44 AM
Box Calculator Apps? db xTc General Car Audio Discussion & Questions 2 11-15-2014 01:56 PM
cant get torres box calculator? Ryan1126 General Car Audio Discussion & Questions 8 06-15-2014 12:46 AM
box calculator 03navi Off Topic Chat 4 06-28-2012 09:56 AM
Torres box calculator HELP!!! loudernu Enclosure Discussion & Design Construction Help 1 05-28-2011 05:59 AM
