Going rate for boxes & walls? - Car Audio Classifieds!
Old 03-07-2016, 09:50 PM
doug118's Avatar
0/11 sssss4674
Default Going rate for boxes & walls?
What are people willing to pay for a box from a successful shop? I'm thinking about having my new box built by a reputable shop but the 2 shops prices vary by a huge margin. One shop has the most musical build I've ever heard from a trunk car, plays 150+ from 25-45hz. They sold me ~$450-500. Another shop has a build that does a 155 but I'm not sure how flat it plays and they want ~$1200. Both builds are in the exact same vehicle, which is the same as mine
I just can't figure out is $450 is insanely cheap or $1200 is high? This is for a 4th order built into the trunk of a car
Old 03-08-2016, 12:54 AM
0/11 sssss3526
Imo 450 is cheap for an in trunk bp build from a reputable shop.
1200 seems high, but we dont know how much prep and or other fabrication your trunk will require. Could be fair if its going to require quite a few additional hours of labor or material outside of the box itself
Old 03-08-2016, 05:43 AM
soze1's Avatar
0/11 ssssss208
$450 is cheap.
Old 03-08-2016, 05:52 AM
massivespl's Avatar
0/11 sssss8409
$450 is what shops charge for a simple ported box
$1500 would be a full trunk Wall built inside the trunk and show quality
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-08-2016, 07:17 AM
0/11 ssssss600
Wow! I had no idea having a box built was so expensive since it costs me $50 roughly for a slot port box that's to the sub specs.
Old 03-08-2016, 07:53 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
450 is a steal of a deal.
My game is legit,
Old 03-08-2016, 07:58 AM
jeffdachef's Avatar
0/11 ssssss440
i'd trade a few DBs for flat and musical anyday. OR even better, just ask them to do adjustable tuning.
Old 03-08-2016, 08:09 AM
doug118's Avatar
0/11 sssss4674
I'm thinking it's both, $450 is cheap and $1200 is on the high end. Cosmetically, they would look identical. Only reason I'm not immediately going with the cheaper shop is because I've heard that they have torn up a few subs in the past before getting the box right and they've never built a BP with sundown subs. The more expensive place knows sundown better than any other brand, and that's what I'm using
Old 03-08-2016, 08:28 AM
andy75's Avatar
0/11 ssssss788
Wow. I can't even buy the material for that.
The Following User Says Thank You to andy75 For This Useful Post:
dangar (03-08-2016)
Old 03-08-2016, 08:53 AM
massivespl's Avatar
0/11 sssss8409
If they can promise you 155db trunk car on music id pay $3000 for that install. That's nuts. My buddy has two zv4s 12s just a plain ported trunk wall built inside the car and sealed off proper and does 150db+ from like 24hz-38hz and he paid about $1000-1500.... But prices will very from where you live.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
C&D high rate series 134 AH $100 darkkon Wiring, Electrical & Other Installation Equipment 33 07-28-2012 11:50 AM
C&D max rate batteries robertawdgsx Bargain Bin 21 10-22-2011 11:36 PM
FS - C&D High Rate Max batteries theFiverMan Wiring, Electrical & Other Installation Equipment 2 01-04-2011 05:31 PM
C&D tech high rate batteries rumproast789 Wiring, Electrical & Other Installation Equipment 8 06-14-2010 12:40 PM
