installed Singer 270a alt but lower voltage? - Car Audio Classifieds!
Old 03-08-2016, 08:10 AM
0/11 ssssss117
Default installed Singer 270a alt but lower voltage?
So my stock 2013 Grand Cherokee came with a 180a high output alt. I decided to have singer recase my alt. Before on my stock alt my charging voltage hot was 14.6, Now with the singer in its 14.1 Why would it have gone down? I know Singer usually has his set points at 14.8. I contacted Mike also to see why. Im hoping the 270a will be much better even though its less voltage. I forgot my vehicle came stock with 180a high out.
Any suggestions? or maybe someone knows why? Im gonna cold start in the morning and read to see where im at. This is testing at the charging point 3 ft away from the alt.
Old 03-08-2016, 08:24 AM
mega fatty
0/11 sssss6008
Is that idle?
Most higher output Alts won't put out as much at idle
Old 03-08-2016, 08:35 AM
Voltage depends on whatever is regulating the voltage, whether it's internal to the alternator, externally regulated (with something like a transpo adjustable regulator box), or computer controlled like some cars have built into the ecu.
Is the 270a all brand new? You mentioned a 180a alt, a stock alt, and a recased alt.
Old 03-08-2016, 08:41 AM
massivespl's Avatar
0/11 sssss8409
It's whatever kind of regulator singer uses... My singer alts would charge at 13.7v... I sold them and swapped them out for excessive amperage now I see 14.6v all day hot
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-08-2016, 09:17 AM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
My singer charges at 14.8 all day and drops to 14.2 full tilt on the bc5500 at .5....
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 03-08-2016, 09:24 AM
massivespl's Avatar
0/11 sssss8409
Yea my buddy has a singer in his Bonniville and it works great 14.4v all day... I ordered two singer alts and both charged at 13.7.... And I know adulbirch on here had the same problem with his singer alt he ordered from singer for his Silverado... It must be whatever regulator he use for Chevy 5.3 motor alts
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-08-2016, 09:31 AM
SPL Farms
0/11 sssss5706
Gotta be Nate, maybe he got a bad batch of them when he ordered his stock? No clue... The toyota is legit as fawk and todds VW is straight wanging power is all I know...lol
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 03-08-2016, 09:34 AM
massivespl's Avatar
0/11 sssss8409
I ordered my singer alts over two years ago and adulbirch just got his like a month ago.... My buddy just ordered a singer for his Ford F-150... Once he installs it I'll report back on how it's doing
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-08-2016, 09:35 AM
Red Light Ear Rapist
0/11 sssss1397
My singer 270 is at 14.6 cold and 14.4ish hot
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 03-08-2016, 09:47 AM
doug118's Avatar
0/11 sssss4674
And now I'm stuck with your old alts lol
FS: Singer gm alts, 270a tacomaguy1 Alternators 16 07-25-2015 01:13 PM
New alt, lower voltage?? davidrforbus General Car Audio Discussion & Questions 69 02-06-2015 04:29 PM
singer 270a alt 5.2l ltr450racer690 Wiring, Electrical & Other Installation Equipment 5 11-03-2013 08:47 AM
H/O alternator (270a) for 3.6L by Singer carshateme Wiring, Electrical & Other Installation Equipment 6 10-11-2013 11:29 AM
270a SINGER ALT for gm trucks bcjerad22 Wiring, Electrical & Other Installation Equipment 1 09-14-2013 08:28 PM
