Alternator Regulation - Car Audio Classifieds!
Old 03-08-2016, 09:05 PM
Team_Green_SQ
0/11 sssssss13
Default Alternator Regulation
Sup guys, a couple months ago I installed a DC Power 250 Amp alt, replacing my stock GM 105 Amp alt. I have a 1997 Chevy 1500 Cheyenne. The plug that goes into the alt is only one pin, not 4 like I usually see for the 1500. My question is, the voltage is only above 14.1-14.3 when its cold, and obviously id like to run a little higher and I don't know how my alt is regulated, and if its internally, is there a way to regulate it externally. Other info is I have 1/0 OFC big three and power wire, a 1/0 CCA negative run back to the front batt and 1/0 OFC grounded in the rear, a 50ah Juicebox in the rear and a stock napa up front. I'm running a MB quart 4.60 and a custom American bass similar to a 175.1 which is about 2-3k if I remember. I'm currently running my amp at .5ohm and drop to easily 11.5 but I try to keep it above 12.8. Any help is appreciated !
Old 03-08-2016, 09:28 PM
Red Light Ear Rapist
0/11 sssss1397
How often do you charge your batts? Surprised your voltage goes that low with what you have on a 250 amp.
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 03-09-2016, 08:10 AM
Lock up your daughters!
0/11 sssss1342
How many pins does the alternator have? Not the stock plug
If it's a 4 pin oval alt, you can hook it up with an external relay and adjust the voltage up with diodes/resistors
My Silverado:
Old 03-09-2016, 12:33 PM
Team_Green_SQ
0/11 sssssss13
I probably should get my batts fully charged up again, is it possible the old napa up front is causing more issues than helping?
Team_Green_SQ
0/11 sssssss13
I do believe its a 4 pin, TheCamBeck owned it before me and I think he had it externally regulated.
Old 03-09-2016, 12:37 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Whats theresting volage of the batts alone?
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 03-09-2016, 01:02 PM
Team_Green_SQ
0/11 sssssss13
BAd, Usually 11.7-11.9
Old 03-09-2016, 01:07 PM
Frank's Avatar
I like twins with A$$
0/11 ssssss377
If that low you need new batteries!!
youtu.be/SWV9r9USAeA (IJUSTWANTTOGETLOUD)
The Following User Says Thank You to Frank For This Useful Post:
Todd Dupler (03-09-2016)
Old 03-09-2016, 02:03 PM
massivespl's Avatar
0/11 sssss8409
Then bltches be dead. Charge them to full and let them sit 24-48hour... If they drop below 12.6 after 24hr I wouldn't use them.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
The Following 2 Users Say Thank You to massivespl For This Useful Post:
djscrubb (03-09-2016), Todd Dupler (03-09-2016)
Old 03-09-2016, 03:14 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Gm 4 pin regulator can be messed with quite easily.
PLFS are the 4 pins on the regulator. If you but a potentiometer between the s and (+) you can lower the voltage the s wire sees and thus will increase the voltage the alt will put out.
Hooking up an external regulator to your alt is pretty easy just gotta hook a wire up to the (+) side of the brush that is behind the regulator
What alternator? Watts16202 General Car Audio Discussion & Questions 71 05-01-2016 03:17 AM
Which alternator would u get? fyerbyrd22 General Car Audio Discussion & Questions 84 02-08-2014 01:25 PM
Dual Alternator kit and 250 Amp Alternator GMC vh14a eBay 0 11-28-2013 05:40 PM
HO Alternator andrewtexas123 General Car Audio Discussion & Questions 0 01-05-2011 11:24 PM
H/O Alternator WannaBeLoud Wanting to Buy (WTB) 8 01-02-2011 08:40 PM
