B2 zero.7 or sundown scv6k - Car Audio Classifieds!
Old 03-11-2016, 07:03 PM
crownvicon26's's Avatar
0/11 sssss1882
Default B2 zero.7 or sundown scv6k
Already have the b2, thinking of selling and getting a scv6k. Will this be worth the swap? Running 3 zv3 15's
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 03-11-2016, 07:25 PM
So Low's Avatar
0/11 sssss1258
The B2 has awesome low ohm performance, the scv will make more power on low voltage.
I wanted one of the zero.7s so badly, but both are awesome choices.
The Following User Says Thank You to So Low For This Useful Post:
crownvicon26's (03-11-2016)
Old 03-11-2016, 07:36 PM
0/11 sssss1882
Since I will be wired to .33 I should probably stick with the b2 right?
Taramps 8k
2 Zv.3 15's
Old 03-11-2016, 07:59 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
IMO keep what you got, @.33 you have close to a 7.5K amp
or get a 10K amp
The Following User Says Thank You to B-Shot For This Useful Post:
Old 03-11-2016, 08:22 PM
0/11 sssss1882
or get a 10K amp
Awesome. Thanks bro.
Taramps 8k
2 Zv.3 15's
Old 03-11-2016, 09:50 PM
0/11 ssssss467
i agree keep what you got... anyone else looking for one the new zero 7 R will be out un less than 2 weeks... if you have any questions pm me
Old 03-11-2016, 10:12 PM
0/11 sssss1882
What's the difference between the zero.7 and the zero.7r?
Taramps 8k
2 Zv.3 15's
Old 03-11-2016, 10:20 PM
0/11 ssssss467
bigger cap bank... better driver card... basically its a revamped version to handle more power
The Following User Says Thank You to unknownuser200 For This Useful Post:
crownvicon26's (03-12-2016)
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
A higher voltage amp 18v. capable (I think) different crossovers , probably a totally different board in the .7 case
Old 03-11-2016, 10:23 PM
0/11 ssssss467
yes i think it did 12k at 18 volt at a super low ohm
NSV2 15s, SCV6k, 4th order LyferXB9s Build Logs 17 05-24-2015 04:34 AM
NSV2 15s, SCV6k, 4th order. LyferXB9s Build Logs 9 05-18-2015 08:56 AM
any news on the scv6k? Fatman489 (Sundown Audio) 5 10-17-2014 06:03 AM
WTT:Brand New Sundown SA D2 15 for 2 Sundown E 15s or 800+ rms Mono Amp dstack2 Car Audio Trader (WTT) 11 12-24-2012 12:52 PM
Another National Record for Team Sundown Russia - 156.2 - Sundown z15v2 Skillz (Sundown Audio) 13 01-23-2012 08:33 PM
