mixing agm and lead acid? - Car Audio Classifieds!
Old 03-14-2016, 05:29 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Default mixing agm and lead acid?
Have 2 stock batteries, they rest at 12.6-12.7
Would 2 hc600's be ok to add to them?
They would it on my amp rack nicely and my voltage drops down to mid 13's sometimes so I would like a bit more battery power. Plus they are only $50 each...
team graham
Old 03-14-2016, 06:02 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
I was always told not to mix lead acid and agm. Agm rests higher and the 2 types will fight each other
My game is legit,
Old 03-14-2016, 06:08 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Mix is no beuno
Old 03-14-2016, 06:19 PM
massivespl's Avatar
0/11 sssss8409
I wouldn't mix and if your not dropping past 13v what's the point?
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-14-2016, 06:21 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Lights dimming
team graham
Old 03-14-2016, 07:01 PM
0/11 ssssss452
What he means is that if you're only dropping into the mid 13's is that you're not even using any of your battery reserve yet, so simply adding more batts wont help your lights or your voltage drop.
The Following User Says Thank You to dakota660 For This Useful Post:
FocusOn20s (03-14-2016)
Old 03-14-2016, 07:04 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
But the second battery helped a lot but now I want to get louder and mid 13's is just where I let it go because of the lights and what not...
team graham
massivespl's Avatar
0/11 sssss8409
Take your uber money and buy Hairpin like 240alt prly be like $300 because I know 350a alts are like $450 from excessive for your car so a smaller alt like a 240amp would be like $300
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-14-2016, 07:06 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Hmm what about 200 or 250 a?
And will it be a direct replacement from stock or will I need extra stuff?
team graham
Old 03-14-2016, 08:01 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Your s1500 draws 120amps your ks300.4 will draw 85amps max and your car (average HHR) uses an average of 62amps that adds up to 267amps if you have the stock bigger 140amp alt the leaves you with -127 amps
Takes power to make power
Tags
agm, battery, hc600, kinetik, lead acid
UPG 45965 Ub-4d Agm Sealed Lead Acid Battery Great battery for your system? team_db's General Car Audio Discussion & Questions 8 04-03-2015 09:24 AM
Mixing AGM and Lead Acid Batteries dwpjr General Car Audio Discussion & Questions 4 01-26-2015 04:06 PM
Lead Acid vs AGM Winter_C General Car Audio Discussion & Questions 1 03-18-2013 07:13 PM
WTB Cheap Car Battery 12v Lead Acid or AGM hoffman777 Wanting to Buy (WTB) 2 02-14-2013 04:26 PM
lead acid to agm..will it help anything?9000w system onefast68 General Car Audio Discussion & Questions 50 02-11-2013 04:45 PM
