grounds spots for sedans - Car Audio Classifieds!
Old 03-18-2016, 06:39 AM
Red Light Ear Rapist
0/11 sssss1397
Default grounds spots for sedans
What are the best spots? seems like the largest single piece of metal is in my wheel well, was thinking of grounding to that and making jumps from that to other spots in the trunk... ideas?
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 03-18-2016, 07:14 AM
mega fatty
0/11 sssss6008
Usually by a seat belt bolt works well
They are connected to sturdy pieces and have some meat to grab
I just ran a neg back up front when I was running more power
Old 03-18-2016, 08:07 AM
0/11 sssss1397
my bolts are unaccessable, and layered to other pieces that all are painted. i need to stay in the trunk or can jump down to underneath the car
4 Crossfire v4 18s
Old 03-18-2016, 11:09 AM
doug118's Avatar
0/11 sssss4674
Strut tower bolts and seat belt bolts are the 2 best spots in the rear of unibody cars. If you can't access either one, I would just find the thickest piece of sheetmetal and test it with the DMM
Old 03-18-2016, 12:39 PM
0/11 ssssss452
I drilled a hole in the floor of the trunk and went straight to the cars frame when I grounded my batteries, and grounded the amp to the inside of the trunk were the hinges come down, then jumped from there to were the seat belt bolt on.
Old 03-18-2016, 12:50 PM
So Low's Avatar
0/11 sssss1258
Every car is different, I've added so many new wires over the years and changed grounding locations so many times I know where all the good grounds are in my boom mobile. And just bc you can read low resistance doesn't mean it's the best ground.
Straight to frame and/or a long run grounded to the alt. That's usually the best way. No sheet metal. Strut towers count as frame. But not having both can be costing you power:
Four 1/0 grounds straight to chassis:
With four 1/0 runs tied in front to back:
Granted it's only two group 34 batteries running one 20.1 at .25 ohm but there's a big voltage drop with less/worse grounds
No clip, no boost, who uses that anyway
The Following 4 Users Say Thank You to So Low For This Useful Post:
Chris McNeeley (03-18-2016), colorblind83 (03-19-2016), jigsizzle (03-18-2016), ludeman (03-18-2016)
Old 03-18-2016, 04:39 PM
0/11 sssss1397
That's a great post, thanks for taking the time to do it!!!!
4 Crossfire v4 18s
Old 03-18-2016, 04:45 PM
0/11 sssss1070
sheet metal is fine for small amps and loads, and probably ideal in most vehicles, maybe not cars. seems like older vehicles, especially trucks, are made with thicker gauge steel
over 200a is when id seriously recommend a dedicated ground run
Old 03-18-2016, 04:51 PM
0/11 sssss1397
Im gonna be around 800 to 900 amps I'm guessing, lol my 4chs are prally around 200 by them selfs
4 Crossfire v4 18s
Old 03-18-2016, 06:01 PM
So Low's Avatar
0/11 sssss1258
Call up electron beam and get some 4/0 ofc. $2.80 a foot. Two runs of that front to back will do. You can run the grounds under the vehicle wherever you can without the same concerns about positive runs. Really doesn't take too long.
Ideal big 3 spots? graham General Car Audio Discussion & Questions 24 05-26-2014 12:32 AM
Any good cliff jumping spots? Jesseland Off Topic Chat 0 01-29-2013 08:21 PM
Always try different spots in your car.. Silenkiller General Car Audio Discussion & Questions 16 12-02-2010 01:51 AM
Best spots to ground my car??..Help Asap!! Benzino713 General Car Audio Discussion & Questions 3 11-06-2010 08:18 PM
Best way to remove oil spots on driveway? Patrick Simmons General Automotive Chat 18 11-22-2008 08:00 AM
