Big 4 Wire Upgrade on Diesel - Car Audio Classifieds!
Old 03-24-2016, 01:17 AM
0/11 ssssss452
Default Big 4 Wire Upgrade on Diesel
Gonna upgrade underhood wiring. My question is can I eliminate the crossover wire from one battery to the other by tapping both battery positives to the alternator output lug? It would eliminate a large length of wire for sure, what would be, if any, the adverse effects of wiring that way?
Missin Texas
Old 03-24-2016, 01:26 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
I'd do a run from the alt to each battery and a run from positive to positive.
My game is legit,
Old 03-24-2016, 01:33 AM
0/11 ssssss452
What do you think the gain of having the crossover wire with the taps off the alt? I have also heard of running wire from the back case of the alt to the neg of the batteries. What is the consensus on that? Its on youtube in a vid from an alt builder
Missin Texas
Old 03-24-2016, 01:39 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Alt case is very good ground. I'm of the belief that you can't have too many grounds.
My game is legit,
Old 03-24-2016, 02:35 AM
0/11 ssssss600
I also think that ^ but doesn't too many grounds raise the possibility of ground loop issues?
Old 03-24-2016, 03:22 AM
0/11 ssssss452
I have never had that experience, actually the opposite. There was a time years ago that I did not use enough/proper grounds and would experience loop issues. Good grounding eliminated ground loop issue for me. I have not grounded my alt case to my battery ground before, a video on youtube gives a good explanation of the positives of doing it so I may try. https://www.youtube.com/watch?v=K3EFGlHPFDk
Missin Texas
The Following User Says Thank You to wanderer1 For This Useful Post:
lalojamesliz (03-24-2016)
Old 03-24-2016, 03:43 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
How is it wired now? Alt to front battery, then front battery to rear battery? And you want to change it to alt to both batteries?
team graham
Old 03-24-2016, 07:09 AM
0/11 ssssss452
Factory Ford single alt for now. Alt to passenger battery, crossover wire to driver side battery. Pretty standard stock wiring. Any comment on the video?
Missin Texas
Old 03-24-2016, 09:31 AM
doug118's Avatar
0/11 sssss4674
Do one or the other. The batteries will be connected at the alt so why add another wire?
Old 03-24-2016, 09:45 AM
So Low's Avatar
0/11 sssss1258
One run from each battery to alt positive, and the alt case is the best ground in the car so definitely run a ground from the alt to battery negative or chassis
WTB: 0 gauge wire "to do big 3 upgrade, how much do i need?" murkr Wanting to Buy (WTB) 24 10-01-2010 01:37 AM
big 3 upgrade 94YukonGT General Car Audio Discussion & Questions 17 08-31-2010 09:43 PM
big three upgrade audiobahnfan (Shok Ind) 3 03-26-2010 04:18 PM
big 3 upgrade fyerbyrd22 General Car Audio Discussion & Questions 44 03-06-2010 12:27 PM
anyone ever big 3 a diesel? michael707 General Car Audio Discussion & Questions 7 09-10-2009 06:21 PM
