coil tick questions - Car Audio Classifieds!
Old 03-26-2016, 02:05 PM
0/11 ssssss600
Default coil tick questions
Hey guys,
I searched around but I surprisingly didn't find my answer. Can I damage amp by using subs (yardsale) with a coil tick ?
They will be in a ported box in my trunk so I doubt the ticking will bother me but I just don't want to damage my amp.
Old 03-26-2016, 02:21 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
if it ohm's out fine run it, if it gets louder check the ohm's again
Old 03-26-2016, 02:57 PM
0/11 ssssss600
Yeah, the ohms are fine on both of them. The box they came in say "tick" and they are QC fail.
Old 03-26-2016, 04:17 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Probably a tick at high excursion. I had a yardsale sub like that. Never heard it in the box and I bumped it hard for a long time until I sold it to a friend.
My game is legit,
Old 03-26-2016, 05:07 PM
williamhung's Avatar
0/11 ssssss536
I've always wondered what causes the tick at high excursion? Is it the coil itself actually coming in contact with something or is it the leads overstretching?
2 Stereo Integrity HT-15's
1 Stereo Integrity HST-15
Old 03-26-2016, 06:18 PM
Turn it up's Avatar
0/11 sssss1933
Misalign coil
Old 03-26-2016, 06:27 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
slight variance/deviation in the spider pick (more resistance in one spot), slightly uneven lead lengths, misaligned coil. in a normal ish gap, theres room for the coil to wiggle but at hih excursion, the deviation gets exaggerated
only issue you "could" have is the tick (usually former hitting pole) wearing through causing a short but its not real common as the pole would act as a simple series conductor
williamhung (03-30-2016)
Old 03-26-2016, 08:29 PM
0/11 ssssss600
They are sa-12 v3 subs.
I need to build the box for them. I took out my current sub to motivate me to build the box sooner
I haven't tested them but I'll try to tonight. I'm just going by what it said on the box (tick)
I hope it's not too bad
Old 03-29-2016, 10:14 PM
0/11 ssssss600
Update:
I tested the subs I received and found the terminal leads very close to the spiders. Before testing them I bent the terminal leads up and tested them.
I didn't experience any ticking while I did a free air test. The only noise was them bottoming out! I guess I got lucky with my purchase. I finished my box today, 3.3 cubes net with a 6" aeroport
and i will install it tommorow with my tramps dsp3k. Thank you Sundown
6 layer coil questions 72impala General Car Audio Discussion & Questions 15 08-13-2015 03:51 AM
how to check for a coil tick king-918 (Sundown Audio) 20 09-12-2014 11:09 PM
Questions about a Sundown Nightshade v2 coil Specification cycosmith0666 General Car Audio Discussion & Questions 2 10-10-2012 09:52 AM
