Anyone know how to wire a 2 -wire chevy cs-130 - Car Audio Classifieds!
Old 03-27-2016, 04:36 PM
Loyal Member
0/11 sssss2152
Feedback Score: 35 reviews
Default Anyone know how to wire a 2 -wire chevy cs-130
Just bought one to upgrade the alt in my new car (91 camry) and I know it's pretty simple but I don't want to fry this sucker cuz then I have to wait another week for one to arrive at O'reillys.
Is it as simple as sense to sense and ignition to ignition? I see it says not to put it on the same circuit as the coil or it'll keep the car running after the key is off so i'm a little scared on that. Do I need to jump anything to the battery connection? Do I need to rewire the lamp to something or a resistor since this alt doesn't have the lamp wire?
I already upgraded the battery wire to 1/0 sky high,but do I need to upgrade the sense wire too since it's a much higher amperage alt (70-80 amps at idle vs 34 amps at idle and 63 amps at 1200rpm)?
Any wiring diagrams would be appreciated of course. The toyota alt is the round plug 3 wire and the chevy is the 2-wire red and yellow plug from a 94 lesabre.
I'm just gonna ask my landlord to hold the car up while I take the tires off. I mean, she's old and all but should be okay.
Old 03-27-2016, 05:24 PM
0/11 ssssss281
Those are really easy you can probably not connect anything and once you rev the car it will excite/charge. But real answer is one wire goes to constant the other to lamp wire.
The Following User Says Thank You to Goldfishrock1 For This Useful Post:
rachidfunaki (03-28-2016)
Old 03-28-2016, 03:21 PM
Loyal Member
0/11 sssss2152
Cool I'm a Ford guy so I don't know much about chevy. In the middle of wiring it right now actually. Just adjusting the mounting arm and i'm done.
Old 03-28-2016, 05:19 PM
0/11 ssssss568
the S is the sense. this is connected to output post. the L is the lamp/turn on. you want to connect this through lightbulb (battery indicator on dash) which is switched power. if you dont have a light circuit, use a 500 ohm resistor on a relay circuit switched on with car.
2007 chevy van radio wire harness Carlos12 General Car Audio Discussion & Questions 3 11-28-2012 06:31 PM
1/0 wire, 4awg wire, fuse holders, speaker wire, baffles, RCA...lots! dacheatham Wiring, Electrical & Other Installation Equipment 4 08-30-2012 06:16 AM
Speaker wire, power wire, battery terminals, in-line fuse holders nyoc2020 Wiring, Electrical & Other Installation Equipment 16 08-13-2012 03:51 PM
wire wire wire 2/0 1/0 4ga & speaker wire dgaf_ Wiring, Electrical & Other Installation Equipment 11 04-08-2012 08:06 AM
WTB: lots of installation stuff (RCA's, power wire, speaker wire) treylittlefield Wanting to Buy (WTB) 23 11-21-2011 01:02 PM
