Thoughts on t/s parameters - Car Audio Classifieds!
Old 03-29-2016, 06:55 PM
0/11 ssssss543
Default Thoughts on t/s parameters
Just finished testing a sub I built that I plan to use in a 6th order. It a dual1 15. Fs 37.68 qms 4.74 qes.294 qts .277 vas 4.323cuft mms 266g b/l 20.49 re 1.96 b/l^2/re is 214 an Spl factor of .8 the ebp 136. I haven't modeled it yet but I think it will do well. Opinions from knowledgeable people appreciated.
Old 03-29-2016, 08:07 PM
So Low's Avatar
0/11 sssss1258
Monster 6th order but the Q alignment is good. What size coil
Old 03-29-2016, 08:31 PM
0/11 ssssss543
3 in coil thin 8layer. Ferrite motor should be good for close to 3 inch p-p mechanical or whatever the x10 spider can handle.
Old 03-29-2016, 08:33 PM
0/11 sssss1085
Feedback Score: 23 reviews
That low of a qts is going to need massive vent area for a 6th. I foresee the proper vent area being too large to handle unless you're filling the back of a Suburban. A mid-q sub of around .4 to .5 would be a lot better, but honestly (people will disagree) IMO it will be better suited in a ported enclosure.
The Following User Says Thank You to hurrication For This Useful Post:
So Low (03-29-2016)
Old 03-29-2016, 09:07 PM
0/11 ssssss543
4 15's two taramps 8k's and 43 cu to work with. About 150sqin of port low side 700sqin high side
Old 03-30-2016, 06:36 AM
0/11 ssssss543
Plan is low side 4.5cu net per tuned to 28 high side 4.75 per tuned to 55. This will be series tuned. Should I use more port area adjust volumes a little ? These t/s are pre break in as well.
Old 03-30-2016, 03:31 PM
0/11 ssssss543
I could possibly do 175 or 210 sqin of port for the low side. High side could run a little over 850 if needed.
Old 03-30-2016, 05:59 PM
0/11 sssss1085
You'll need to model it to see the port velocity with the power you plan on. A good guideline is to stay under 25 meters/sec on the velocity.
ZV4 t/s parameters? josh09 (Sundown Audio) 1 10-18-2013 04:11 PM
Anybody Know T/S Parameters Azalin_00 General Car Audio Discussion & Questions 5 01-02-2013 07:42 AM
DC Audio t/s parameters codyj18 (DC) 0 07-20-2012 02:26 PM
Sub parameters ianlahood13 General Car Audio Discussion & Questions 4 02-22-2011 11:01 PM
Need T/S parameters in Wisconsin resko1 General Car Audio Discussion & Questions 8 12-11-2009 09:43 AM
