Sub builders- voice coils - Car Audio Classifieds!
Old 03-30-2016, 09:55 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Default Sub builders- voice coils
Would like a small collaboration on the subject of voice coil dimensions. More specifically, the dimensions for the most universal coil .
For example
3" inside diameter, 3.2 outside diameter
If that makes sense. Basically, I'm likely going to start prototyping coil designs again and would like to know the most general universal dimensions you can think of to allow them to be most usable for users to try out
Old 03-30-2016, 10:43 PM
0/11 ssssss606
Lol I need 4in coils Id 3.96 OD 4.20
Old 03-30-2016, 11:18 PM
So Low's Avatar
0/11 sssss1258
I usually assume pole OD is about 2.92 and the bigger 8 layer coils shouldn't exceed 3.3 OD so somewhere in between there. I think 3 ID to 3.2 OD is spot on
Old 03-31-2016, 12:23 AM
Authorized Vendor
0/11 ssss14115
the coil design im working on now has a rather complex mathematical procedure to get the ww, dcr and od to line up within spec. change one a tiny bit and the rest get wonky. as of now looks like 3.00 id 3.206 od which will allow my dcr to hit the targeted D1.5 ohm (1.49 to be exact) . this is a 2 x 2 design. other diameters and such to be explored once finalized designs/finished prototypes are completed and test good
miller83815 (03-31-2016)
Old 03-31-2016, 06:04 AM
0/11 ssssss543
8layer id of 3.018 od 3.24-3.265 is very common
Old 03-31-2016, 06:09 AM
Authorized Vendor
0/11 ssss14115
Why 8 layer at that diameter?
Old 04-01-2016, 05:09 PM
0/11 ssssss543
Most 4 layer I've used have an od in between 3.17-3.22. As far as id I prefer dealing with 3.018 over the 3.000, unless there is a extra small pole smaller than 2.965.
Old 04-01-2016, 05:23 PM
Authorized Vendor
0/11 ssss14115
with a 3.26 i could make that a 4 layer without issue and would prefer a 4 layer anytime possible over an 8. the 3.0 isnt set in stone btw
Old 04-02-2016, 11:06 AM
0/11 ssssss543
Curious as why you prefer 4 layer over 8. Creates more daily friendly less peaky subs?
Old 04-02-2016, 11:08 AM
So Low's Avatar
0/11 sssss1258
Inductance and thermal release.
4" Voice Coils RustyWCA Speaker Accessories & Parts 12 04-21-2013 11:59 PM
FS - 3" Voice Coils bwoodroof Speaker Accessories & Parts 8 09-10-2011 08:37 AM
Need 2.5" Voice coils Dunbar91 Wanting to Buy (WTB) 15 06-10-2011 10:35 PM
3" voice coils tangelo95 Wanting to Buy (WTB) 2 04-19-2011 05:44 PM
dual voice coils kmall002 General Car Audio Discussion & Questions 2 03-24-2010 03:44 PM
