what makes a Brazilian amp pop? - Car Audio Classifieds!
Old 03-30-2016, 11:06 PM
0/11 ssssss600
Default what makes a Brazilian amp give up the magic smoke?
I've been running my dual 1ohm taramps dsp3k with my dual 1.4 ohm sub for 5 months now at .7 ohms and it's never heated up or caused problems.
I soft clip according to the clip light every now and then.
Why do these amps fail when wired below rated?
Is it just too much current flowing through the board when wired lower and pushed harder? I've read TaylorFades threads but im still curious. I've read several threads on these amps when I bought my amp but I'm just curious on what people think. No bashing please
Old 03-30-2016, 11:19 PM
Mayhem's Avatar
0/11 ssssss175
i've never ran brazilian so shot in the dark answer based on readings.
You could have a lot of box rise? ** reason its not blowing, not a reason it will blow **
Felt like i needed to edit that in.
I fart at 30hz
The Following User Says Thank You to Mayhem For This Useful Post:
lalojamesliz (03-31-2016)
Old 03-31-2016, 06:00 AM
SPL Distribution Owner
0/11 sssss2983
Mounting them poorly. This causes failure with any amplifier. Just so happens, the failure potential is higher with brazilian amplifiers because they weigh less.
Having too high sustained charge voltage.
Brazilian amplifiers never stop making output power so if you keep driving them in voltage, which is equal, to an infinite volume control or setting gain stupid high.. it will eventually pop the FETs or the microcontroller (usually from excessive rail output)
There is a general guideline of DC voltage to stay within so that doesnt happen.
It works fine too.
That's basically it.
Everyone should know not to wire below their stable load.
Taramp's has recently released a couple new amplifiers with 5way system protection like korean amplifiers and more focus on vibration control to help aid in the "abuse" some users put amplifiers through.
Between now and the next couple years, Taramp's is going to look different.. Much revisions coming.
The Following User Says Thank You to shizzzon For This Useful Post:
Old 03-31-2016, 06:56 AM
0/11 ssssss281
I get the fact of its trying to make more power then the components can actually handle. I charge at 14.8 steady. What kind of ac voltage should I set my gains to on an hd8000?
The Following User Says Thank You to Goldfishrock1 For This Useful Post:
Old 03-31-2016, 07:12 AM
w00tah's Avatar
Just A Quiet Guy
0/11 sssss1908
It works fine too.
Hopefully someone like Taylor gets his hands on a new one to prove that protection system works. There's always going to be those few who will say they suck no matter what Taramps does to them. Hopefully this will alleviate some of those naysayers.
2004 Chevy Aveo-
Alpine-Eclipse-Vifa-Polk-CT Sounds-Sundown-Knu Konceptz
Essque on a budget
Team Quiet/Team SPL Farms
The Following User Says Thank You to w00tah For This Useful Post:
Old 03-31-2016, 09:24 AM
0/11 ssssss600
It works fine too.
I've never seen one of my Toyota cars/trucks go above 14 volts so I'm good on that.
Should I increase the output on my audio control lc8 converter to keep the gain on my amp lower?
So, is it the amount of current that blows these amps when you try take the maximum rated RMS when you wire too low that blows these amps? Or does something just get damaged no matter how hard you push the amp when you wire below rated and eventually failure?
I've been really happy with taramps so far. I'd like to upgrade to a bigger model but I I'll have to sell this one and I really like the 2.5yrs of warranty I have left
Old 03-31-2016, 09:38 AM
0/11 sssss1070
"Any amplifier outside it's operating limitations will cause it to fail"
Pretty much a blanket statement that's true. Brazilian operating limitations are just different
The Following User Says Thank You to mitchell0715 For This Useful Post:
Old 03-31-2016, 09:43 AM
0/11 ssssss600
I know what you mean. I was just curious if anyone knew the specific cause for failure.
Old 03-31-2016, 10:27 AM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3111
Feedback Score: 57 reviews
Amp vibrations
Wiring under ohm load
Over 15volts.
Only things I can think of.
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
The Following User Says Thank You to SPLpizzaguy For This Useful Post:
Old 03-31-2016, 11:12 AM
0/11 ssssss600
Ok, thanks guys
Brazilian amp low freq roll off jprophet123 General Car Audio Discussion & Questions 18 08-28-2015 07:49 AM
amp pop jezus43130 General Car Audio Discussion & Questions 7 03-10-2012 09:30 PM
My amp makes noise when i turn off power Dirtbikerrob General Car Audio Discussion & Questions 12 08-28-2011 01:12 AM
Amp shut off sub pop Alek17 General Car Audio Discussion & Questions 27 08-27-2011 12:36 AM
trying to find an amp that makes decent power at half or 2 ohm wahvtec General Car Audio Discussion & Questions 10 03-24-2010 05:00 PM
