amp rack almost done - Car Audio Classifieds!
Old 04-01-2016, 08:23 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Default amp rack almost done
Just need to drill holes for sub speaker wires, sub power, and both remote input wires.
team graham
Old 04-01-2016, 08:46 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Your fuse is going to leak mounted like that.
Lookin clean so far!
Old 04-01-2016, 08:51 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Not sure where to mount the holders.
I'm thinking right under each amp though.
is 8" too far away from the amp?
Gonna drill a hole at terminals then bring it back up right under the amp, then back under again to battery.
team graham
Old 04-01-2016, 08:56 PM
chasinbass's Avatar
0/11 ssssss247
Looking good
Old 04-01-2016, 08:58 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Put them where you want, you have pretty short runs i would do closer to the batterys myself.
Old 04-01-2016, 09:03 PM
Lock up your daughters!
0/11 sssss1342
I don't think 8" is too far from the amp.
I'd actually put it much closer to the batteries. The fuse is intended to protect the wire if there's a short to ground. Right now, if your fuse holder shorted out to ground before the fuse, the wire would burn up and possibly start a fire...
My Silverado:
Old 04-01-2016, 09:11 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
So should I fuse battery to sub amp, battery to 4 channel amp, and battery to battery, as well as battery to alt?
Both batteries in the back.
Only fuse is right before sub amp, lol...
IF battery to battery, fuse in between both or right at terminals for both (2 fuses)
team graham
Old 04-01-2016, 09:29 PM
If you only have that one fuse I would take it off the amp line completely and put it on that pinkish wire on the bottom left of the last picture as close to the battery as feasible. Might also want to secure those batteries somehow. Even spray foam around them to hold them in place is better than nothing.
Otherwise the amps look great there!
Old 04-01-2016, 09:40 PM
0/11 sssss1342
Yes, you should fuse all of those things.
I don't run fuses between my batteries because I have them securely mounted
Also, secure those batteries down! Your positive and negative posts are awfully close together in the middle. I'm surprised they haven't shorted when you turn corners
My Silverado:
Old 04-02-2016, 05:53 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
team graham
Tags
crescendo, crescendo audio, crescendo s1500.1, crescendo s800/4, crescendo symphony
Amp rack Mountaindew General Car Audio Discussion & Questions 1 11-13-2013 11:55 AM
First amp rack. djspl General Car Audio Discussion & Questions 1 08-24-2011 03:47 PM
HD amp rack ?'s onebadmonte General Car Audio Discussion & Questions 1 02-19-2011 10:34 PM
Amp Rack RidnClean General Car Audio Discussion & Questions 12 01-24-2009 08:17 PM
Need Ideas for Amp Rack and Battery Rack! BassikInstincts General Car Audio Discussion & Questions 8 01-15-2009 10:36 AM
