Recommend me a Dual 2 ohm 10. - Car Audio Classifieds!
Old 04-01-2016, 08:25 PM
0/11 ssssss351
Default Recommend me a Dual 2 ohm 10.
I have a Sundown Sd-3 10 that is making some noises when it plays like it is coming apart but everything is all glued down and look ok so I am just going to replace it.
The box is a sealed box with about .7 cubic ft. and the amp is a Sundown SAE600d I am running at 1 ohm so it needs to be able to handle 750 watts. The box says it has 9 inches of mounting depth but it is shaped weird so I had to shave some of the corners on the inside to make room for the magnet to fit in but the motor on that sub is flat and wide because it only requires 4.75 inches to mount.
Old 04-01-2016, 08:39 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
http://www.b2audio.com/is they can be had for around $130ish if you shop around
http://www.b2audio.com/wp-content/up.../el_is_man.pdf
Old 04-01-2016, 08:56 PM
0/11 ssssss351
That's a pretty good price considering I paid over $200 for a sub that lasted 6 months.
Old 04-01-2016, 08:59 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
If you bought it new it should be under warranty?
Old 04-01-2016, 09:01 PM
0/11 ssssss351
I bought it online and I am not sure who I got it from and it probably isn't. I was actually looking at a DD 610. I'm using a M4a in my other car and love it so I was thinking of trying out their subs. Would that sub work?
Old 04-01-2016, 10:45 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
The 610's are intended for ported boxses.
Old 04-02-2016, 06:33 AM
0/11 ssssss351
I know it wouldn't be ideal but should work ok. I was also looking at la Soundqubed or Incriminator Audio 10.
Old 04-02-2016, 06:37 AM
0/11 sssss1513
Feedback Score: 17 reviews
Alpine type r 10, I have a pair. They are beasts in small sealed boxes. I also have the grills for them
The Following User Says Thank You to Timhof13 For This Useful Post:
B-Shot (04-02-2016)
Old 04-03-2016, 07:54 PM
0/11 ssssss351
Do you want to sell one of them? Are they dual 2 ohms?
Old 04-05-2016, 08:19 AM
0/11 ssssss351
I've looked and looked for this sub and the only place I found that would even respond to be said they are out until end of May.
2 SXX v2 dual 4 ohm 15's dual tinsel upgraded jrcf71 15" Subwoofers 6 09-17-2015 03:04 PM
2x Dual 2ohm subs... .5 ohm amp or 2 ohm amp? jayd41 General Car Audio Discussion & Questions 42 01-24-2013 02:14 PM
2 15'' L7 Kickers (dual 2 ohm) + Dual Vented Enclosure - Maryland/VA/DC Area 84Benzo Craigslist Deals 0 05-16-2012 05:38 PM
what are some powerful 2 ohm amps that you guys would recommend munches4bass General Car Audio Discussion & Questions 8 01-23-2011 05:23 PM
18''fi bl dual 1 ohm 1badyukon804 18" Subwoofers 1 01-17-2010 08:22 PM
