Sub flutters 15-25 hz with lc-1 at 60-75% - Car Audio Classifieds!
Old 04-02-2016, 06:00 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Default Sub flutters 15-25 hz with lc-1 at 60-75%
I recently noticed the sub is playing a low volume 15-25 hz tone when the lc-1 is at about 2pm-4 pm on a clock when max is 5:45ish if that makes sense.
full gain on lc-1 and it goes away. Lower gain on lc1 also makes it stop but I can't tell if it's just defaulting this way.
So I'm assuming it's the lc-1 but maybe it's the unit? Had to ground rca-s (pioneer pico fuse)
also, sub thumps at source change, turning volume to 0 (only happens from 0-1 or 1-0) and at startup.
swapping unit tomorrow for the bt948hd I got a few weeks ago...hoping it solves it but if not...any ideas?
team graham
Old 04-02-2016, 07:16 AM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Run a 10 or 12ga wire from your amps ground to your headunit sense you are going to swap out, this will eliminate alot of headaches later with ground loop noise and poping and such. my guess would be the lc-1 the potentiometer in them are cheaply made
The Following User Says Thank You to B-Shot For This Useful Post:
graham (04-02-2016)
