Fuse trouble - Car Audio Classifieds!
Old 04-03-2016, 01:06 AM
0/11 sssssss14
Default Fuse trouble
I'm running a Skar audio sk2500.1 at 1ohm on a pair of ddx's with an energie pb2800 battery in the rear and my having trouble with it messing up fuse holders.. It's not actually blowing the fuse, I'm running 0awg with a 150amp anl fuse. The first one it left a little burn spot on the side of the fuse holder and quit working again it never actually blew the fuse with that holder so I bought a new one same size 150amp anl changed everything worked good for a while and all of a sudden quit one day that fuse holder looked like it had condensation inside it but that's not possible it was inside the car the entire time.. And the little section of wire coming off the fuse holder in each direction was warm but by the amp and battery it was still cool, I don't understand. I run it direct with no fuse not a problem at all the wire doesn't get warm the amp stays cool. And also I've never had the fuse under the hood in between battery to battery blow it's always stayed good and is also a 150amp anl.. I hope someone can charm in here and tell me what's going on! Would prefer to have a fuse between that secondary battery and amp. Thanks caco!
Old 04-03-2016, 03:09 AM
Pictures? Heat means there's resistance somewhere; either a loose or corroded terminal, fuse, holder, etc. If it's getting hot enough to cause steam in the fuse holder that's not good, lol.
Old 04-03-2016, 07:38 AM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
That amp will draw a little over 200a at times, something to think about. You should be using a 250a fuse http://skaraudio.com/SKManual.pdf
Old 04-03-2016, 08:25 AM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Get a better fuse holder. I prefer ones with lugs that dont require a terminal
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 04-03-2016, 08:51 AM
0/11 ssssss281
I had that happen a few times culprit being the type of terminal I used. Was using the cheap super hard to crimp gold plated junk changed to copper o-ring problem went away. Make sure everything is super tight.
Old 04-03-2016, 10:53 AM
0/11 sssssss14
Thanks for the responses everyone I'll add a couple pics of the type of wire I'm using and the second fuse holder.. Didn't keep first one. Connections are all tight and I checked terminals this morning with magnet they are all copper?? the spot on this second fuse holder won't let the fuse holder come apart now like it melted the plastic to the copper itself.. Thanks again everyone.. Well maybe it won't let me upload photos.. I'll keep trying tho!
Old 04-03-2016, 11:06 AM
Team SPL Farms
0/11 sssss5000
Where in ohio mojo?
Kenwood ddx470
Old 04-03-2016, 11:10 AM
0/11 sssssss14
Little town just outside defiance bro! You local here in the buckeye?
Old 04-03-2016, 11:20 AM
0/11 sssssss14
Old 04-03-2016, 11:28 AM
0/11 sssssss14
[IMG][IMG][/IMG][/IMG]
4ga Wire, Fuses, Fuse Blocks, Fuse Holders, and USB Cables hari-bhari Wiring, Electrical & Other Installation Equipment 3 05-30-2012 04:14 PM
wtb 17-20 foot run of 1/0, anl fuse holder, 200 amp fuse remi_357 Wanting to Buy (WTB) 2 12-13-2010 10:32 PM
[SOLD] KnuKonceptz In-Line Waterproof ANL Fuse Holder w/ Fuse SPY Wiring, Electrical & Other Installation Equipment 5 06-04-2009 02:51 PM
[SOLD]Knu Konceptz Mini ANL Fuse Holder w/fuse NoPh33rRaCiNg Wiring, Electrical & Other Installation Equipment 2 04-17-2009 10:05 PM
