Alpine headunit issues?? - Car Audio Classifieds!
Old 04-05-2016, 10:13 PM
highpsicobra's Avatar
0/11 ssssss260
Default Alpine headunit issues?? UPDATE...please look
I have a little daily driver and it has an older alpine 9886 headunit in it. Well for whatever reason I can't get to bass/treble settings. It just goes from sub level / defeat / and fader. No eq settings comd up at all.
Anyone with alpine or general head unit knowledge that could help me out.
I do realize this is an alpine model that comes with an imprint box as an accessory that you buy and hook up to the unit to really tune in specific bands but even without that wouldn't it have the basic eq adjustment settings?!?
Thanks in advance
Old 04-06-2016, 12:03 AM
indytrucks's Avatar
CACO Late Night Crew
0/11 sssss5387
It's been a while since I had my 9887 but make sure the dip switches on the bottom of the unit aren't set for imprint. That may be your issue.
http://support.alpine-usa.com/produc...M_CDA-9886.PDF
Starts on page 29. Get to trouble shooting.
Old 04-06-2016, 09:51 AM
0/11 ssssss260
This is a pic of the headunit for reference.
Old 04-06-2016, 09:52 AM
0/11 ssssss260
Thanks for that.l info. I'm going to look into that today!!
I'm going to mess with it for a little bit and if I can't get it to work I'm tossing it and replacing it with a headunit of my choice. It came with the car when I purchased it so I'm not at all attached to it.
Old 04-06-2016, 11:36 AM
0/11 ssssss260
OK,
so I think I realized what the issue it. Decided to pull the H/U out and from what I can see is all the speaker wires have been bypassed.
They had an aftermarket JL 4channel amp installed with components. So basically what they did was splice the factory speaker wires at the DIN location and extend them to the amp under the seat. So no speaker wires are going into the H/U at all.
Im assuming all tuning for treble and bass would have be done at the amp then. Is this the correct way to install aftermarket amp/components?
I know in my tahoe I had arc audio 4080d's hooked up to infinity components and I still had accessibility to adjust EQ settings at my kenwood H/U.
Thanks for the help.
Old 04-06-2016, 03:28 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
I thought even with an amp via rca, the treble and bass settings would still work.
it's more likely the defeat settings that is doing it.
team graham
Old 04-06-2016, 04:13 PM
0/11 ssssss260
That's exactly what I thought. Because I've had numerous systems with aftermarket headunit / amps and always was able to change those settings on the the headunit. I've always had Kenwood headunits though. So not sure on alpine.
Damn.
Old 04-06-2016, 04:27 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Did you check the defeat settings?
I think one is for the imprint module and disables head unit EQ control and the other lets you control via head unit.
team graham
The Following User Says Thank You to graham For This Useful Post:
highpsicobra (04-07-2016)
Old 04-06-2016, 07:38 PM
Brand New Members
0/11 ssssssss1
Try pressing and holding the audio button. It should then open the advanced tuning options. Well that's been the case with the alpine units I've had in the past.
Old 04-07-2016, 12:15 AM
0/11 ssssss260
Man, that was exactly what it was. Swapped defeat setting and they appeared.
Much appreciated!
Alpine CDA-117 Headunit & Alpine CHA-1214 12-disc CD Changer Ai-NET Goindef154 Head Units, Processors & EQs 4 05-05-2016 05:50 PM
Alpine iPos adapter issues. jmelton86 Off Topic Chat 0 04-04-2012 09:13 AM
Lot of 5 alpine head units cd mechanism issues ivaylonikolov Broken & Non-working equipment 8 02-22-2012 12:35 AM
Question on alpine headunit soloithz General Car Audio Discussion & Questions 3 10-30-2010 11:01 AM
WTTF alpine headunit aviator08 Car Audio Trader (WTT) 0 11-21-2009 03:27 PM
