grounding system help - Car Audio Classifieds!
Old 04-08-2016, 09:56 AM
CHRISGIBSON333's Avatar
0/11 ssssss332
Default grounding system help
Is it super important to run a ground wire from front to back of the vehicle?Also what are the benefits if any of doing so. Do i need to run the grounds directly from battery bank to amp? Or can i just ground them to the frame.Thanks for the help
Old 04-08-2016, 10:05 AM
Red Light Ear Rapist
0/11 sssss1397
If you have SUV/truck ground to the frame, low power systems in cars ground to spots in the trunk, high power needs deicate runs need to go back up front to the alt. And no matter what your amps power and grounds should be directly from your bank, and ground the bank.
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 04-08-2016, 10:15 AM
0/11 ssssss332
running 8k
Old 04-08-2016, 11:05 AM
0/11 ssssss600
I keep seeing the more grounds the better.....
Old 04-08-2016, 01:13 PM
0/11 sssss1397
Correct, and on a true 8k you will need the dedicated from back to front up to the alt, personally I'm doing 4 runs of 3/0 on 12k before rise.
4 Crossfire v4 18s
Old 04-08-2016, 01:14 PM
0/11 sssss1397
So low I see you lurcking, you got the knowledge, share it
4 Crossfire v4 18s
Old 04-08-2016, 02:02 PM
0/11 ssssss332
thanks for the input.. looks like i have some work to do
Grounding ??? HOYT4X General Car Audio Discussion & Questions 13 04-12-2014 08:11 PM
Grounding HU. Austin175 General Car Audio Discussion & Questions 5 06-07-2012 10:04 PM
grounding burd337 General Car Audio Discussion & Questions 13 07-07-2011 10:16 PM
Grounding my system LowLyfe General Car Audio Discussion & Questions 3 03-15-2011 12:47 PM
Grounding trunk hit hard like kimbo General Car Audio Discussion & Questions 16 02-13-2011 10:00 PM
