2 6.5"s will fit in center at floor - Car Audio Classifieds!
Old 04-08-2016, 11:24 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Default 2 6.5"s will fit in center at floor
Would this be a good placement?
Near the gas pedal on both sides...would look clean and fairly hidden and out of harms way...
pics if needed.
2 4 ohm each side @ 2 ohms per channel on s800/4, crossed at 300 or so?
Probly 4 sme.654 but open to other suggestions.
I found the 8 ohm older sme.658 louder than powerbass 4 ohm pa mids. I forget how i wired them but I believe they were on a single 4 ohm channel on the ks300.4 so like 50w each. Slightly bigger motor as well
I can probly trade 2 of the powerbass pa mids for a second pair of the 8 ohm older sme's...or should I get 4x 4 ohm?
not sure I want to spend $280 on the un's....
I have a xm-4040 or ks300.4 to power them if needed...not sure what would work best...just need louder vocals...already got tweets figured out
don't want to cut up anything. It's this or just on the floor near door jam
pics in a sec
team graham
Old 04-09-2016, 04:44 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
I might cut the vents a little to fit better. Easily replaced and not easily seen so I don't mind modifying those.
Any suggestions on materials to use? I'd like it to march the existing plastic if possible.
team graham
Old 04-09-2016, 08:05 AM
massivespl's Avatar
0/11 sssss8409
Door panels
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 04-09-2016, 04:28 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
I don't want to cut anything up :\
team graham
Old 04-09-2016, 05:31 PM
mega fatty
0/11 sssss6008
Buy replacement door panels and save the better ones if you plan to resell
Should be able to get a pair for $100 or so
Old 04-09-2016, 05:52 PM
massivespl's Avatar
0/11 sssss8409
They bolt right on and only have to cut to clear speaker motors.. If you got some super shallow neo 6.5s you wouldn't even need to cut anything
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Strong motor for a 4" coil that will fit my 15" Ti basket AudiophilesEngineering Wanting to Buy (WTB) 12 04-01-2014 04:03 PM
Wall building....contoured floor vs raised floor Wagonized General Car Audio Discussion & Questions 9 02-02-2013 06:04 PM
Can 2 15"s fit? theFiverMan Enclosure Discussion & Design Construction Help 6 01-13-2013 04:43 PM
WTB: 4-18" baskets to fit 4" coils beatnbronco Wanting to Buy (WTB) 0 01-05-2013 09:47 PM
(SOLD) 12" soft parts.[fit 4" coil] Violence* Speaker Accessories & Parts 13 12-22-2010 10:41 PM
