dual vs single port on dual sub box - Car Audio Classifieds!
Old 04-11-2016, 04:01 AM
0/11 ssssss600
Default dual vs single port on dual sub box
Why do prefab boxes for dual 12's usually have a port and a chamber for each sub? The dual 12" sub box I just made is my first dual sub set up and I have a single 6" aeroport with the subs sharing the same chamber.
It sounds cool but I'm wondering if it would sound better with each sub with its own chamber and aeroport....
What do you guys think?
Current box, 3.2 net with two sa-12 v3 subs wired at 2 ohms on my taramps dsp3k
I'm happy with the output but I always want MORE!
Old 04-11-2016, 04:50 AM
Assuming equivalent port area, a single port will almost always be more efficient and louder. If the prefab uses round/aero ports, multiples are probably less expensive to manufacture because smaller diameter pipe is cheaper.
The Following 2 Users Say Thank You to SPLEclipse For This Useful Post:
e46inperrycounty (04-11-2016), lalojamesliz (04-11-2016)
Old 04-11-2016, 05:58 AM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
The other reason you will see this is preferred tuning. At times a single 12" aero is unfeasible due to the length needed to achieve desired tuning so guys will opt for multiple smaller diameter ports that will be easier to find room for the required length to achieve tuning. Also some guys are super anal and will do it to have symmetry. Why would someone compromise performance for looks you might ask.... because OCD....
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
The Following 2 Users Say Thank You to e46inperrycounty For This Useful Post:
lalojamesliz (04-11-2016), Todd Dupler (04-11-2016)
Old 04-11-2016, 06:35 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
I've only ever had a single port on all my dual sub boxes. If I want more output I'd need more cone area . My current setup is surprisingly loud for 2 little 8"s.
My game is legit,
The Following User Says Thank You to BallzFast For This Useful Post:
Old 04-11-2016, 07:10 AM
0/11 ssssss600
But what about each sub having its own chamber guys?
I would think that costs more $$$ to make. Also using slot ports takes up more internal space and raises the tuning.
Old 04-11-2016, 07:40 AM
SPL Farms
0/11 sssss5706
Each woofer in its own chamber is a loss on meter in every situation I can think of. The only time it is a good idea in my opinion is when it is for the sealed side of a 4th so that if you blow softies out on one woofer the others don't unload through the now non sealed enclosure and eat themselves as well. Still a loss on meter in that circumstance as well though but the precaution is worth the loss to about half of the guys out there
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
The Following User Says Thank You to e46inperrycounty For This Useful Post:
Old 04-11-2016, 08:10 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Tuning can be adjusted.
My game is legit,
The Following 2 Users Say Thank You to BallzFast For This Useful Post:
Old 04-11-2016, 09:54 AM
0/11 ssssss600
Thanks guys. Like I said, I'm happy with my setup but I have a few friends that like the many boxes I've built (single sub and this 1st dual) and they want me to build them boxes now for dual subs with a single 6" aeroport
I don't want to make a crap box for them
single 4 a dual 2?? turbo_bama General Car Audio Discussion & Questions 8 04-09-2014 01:57 PM
FREE BOX! 18" Box, dual 6" aero port snb778 Wiring, Electrical & Other Installation Equipment 17 11-09-2010 07:12 PM
Single 15 dual slot port or dual L port box Hless421 Enclosure Discussion & Design Construction Help 3 09-26-2010 05:54 AM
