Ground to Chasis question - Car Audio Classifieds!
Old 04-12-2016, 03:19 PM
West1's Avatar
0/11 ssssss231
Default Ground to Chasis question
Before I poke holes in my truck, is there a specific location people drill?
Example, do you drill through the floor and run wire along the bottom to the chasis or do you run the wire inside the vehicle to the far left/right and drill through?
Stupid question but I'd rather ask a retarded question and be sure than drill an open area away from gas tank etc... that could create an issue.
Thanks.
Purchased from- Melverc/SA Amp
Old 04-12-2016, 03:34 PM
0/11 sssss1070
Thanks.
depends on the vehicle. if its a full size truck and you have multiple runs id run it along the frame and then drill a hole in the back wall up pretty high to avoid water intake (still seal it) and use a thick grommet to avoid the wire casing from being cut
The Following User Says Thank You to mitchell0715 For This Useful Post:
West1 (04-12-2016)
Old 04-12-2016, 03:41 PM
West1's Avatar
0/11 ssssss231
I didn't think about grommets. Its a frontier, not the standard truck size but the 2nd bigger generation frontys. I need to run 2, one for highs and one for lows.
I hope this will fix the newly sounding static noise. Reading up, It may be the dreaded Pioneer pico fuse on a fairly new NEX.
Much appreciated mitchell
Old 04-12-2016, 03:45 PM
0/11 sssss1070
should still have a space between the bed and cab? unless its like an avalance and its all one piece.
if you're running a relatively small system you can get away with 1 1/0 ofc run to a distro block and out to your amps.
if you have a large monoblock that pulls over 200a i highly recommend a dedicated ground run along the frame with your dedicated runs for your mids/highs amp and monoblock
Old 04-12-2016, 03:56 PM
West1's Avatar
0/11 ssssss231
124x4 for highs and 1100 for sub.
I believe the sundown mono is a 100a fuse.
What do you mean by dedicated run along the frame? Example, highs for one side of chasis and sub for other side?
Old 04-12-2016, 03:58 PM
0/11 sssss1070
with that type of power just run a 1/0 ofc run to the back to a distro block with 4ga ofc going out to your amps.
you should be able to just run it along the floor inside the vehicle and through the factory grommet on the firewall.
dont waste your time with the whole frame rail thing for that amount of power
the dedicated ground i was referring to was to replace your chassis as the grounding point, considering your power needs you can use the chassis as a ground just fine but upgrade your big 3
Old 04-12-2016, 04:20 PM
mega fatty
0/11 sssss6008
Google pioneer pico fuse fix
It's easy to do and a must if you have a pioneer with whine
And you could run one wire and use a distribution block to wire to each amp
Old 04-13-2016, 08:43 AM
West1's Avatar
0/11 ssssss231
Whats it called when you replace the chassis as ground?
Currently the shop grounded both amps to a factory screw on the back wall of the cab and a factory screw on the floor near the seats. Since I had no static noise with the FLS 125.4 for the past few months I thought everything was all good.
As soon as that annoying sounded started, I jumped on the web and learned about this pico issue. I will do this also. It sounds like your basic static noise plus the sound of wind through a phone. Its loud and extremely annoying lol.
Both amps have their own wire and fuse to my battery or do you mean grounding them together to chassis?
Old 04-13-2016, 03:25 PM
mega fatty
0/11 sssss6008
You can do both
One run of powe
One run for ground to chassis
It can give it a nice look and clean up some wires
Old 04-13-2016, 03:49 PM
West1's Avatar
0/11 ssssss231
You can do both
One run of powe
I originally had one run for power but wanted separate fuses per amp, so we ran 2g per amp. Might be 1g, don't remember.
For ground, I can have both highs and lows ground join together and drill it to the chassis? The shop told me it was a bad idea and would cause a short.
Ground Question Black Toyoda General Car Audio Discussion & Questions 9 11-15-2013 07:23 AM
Just added a battery...Ground question. Blake71091 General Car Audio Discussion & Questions 26 07-17-2012 05:00 PM
Question about ground loop rxer311 General Car Audio Discussion & Questions 18 08-21-2010 12:52 PM
Ground question. davidrforbus General Car Audio Discussion & Questions 12 06-08-2010 01:52 AM
ground question gbo559 General Car Audio Discussion & Questions 7 12-18-2009 10:53 AM
