another day, another issue - Car Audio Classifieds!
Old 04-12-2016, 05:17 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Default another day, another issue
Installed a new unit. Thought the sub was a little quieter but didn't think much of it.
Had to turn lc-1 up higher to get same output.
Took a left turn kinda fast and the decibel output jumped up like it was before but kinda faded in and out like something was loose.
Checked coils, both read the same (inverted but both read 2.8)
Only thing loose is one battery but my connections are solid and the battery doesn't move that much anyway.
What could cause this?
How often do lc-1's go out?
http://i.imgur.com/vWe834w.jpg
team graham
Old 04-12-2016, 05:27 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Just to clarify, what is the "unit" you replaced? the LC-1?
Old 04-12-2016, 05:29 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Had p5000ub, upgraded to bt948hd
team graham
Old 04-12-2016, 05:52 PM
Partially Unwound
0/11 sssss2697
Oh, Headunit...Sorry no advice or words of wisdom.
Old 04-12-2016, 05:57 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
every time you have an issue the lc-1 is involved
Old 04-12-2016, 06:19 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
You're right...time for the proprietary knob?
team graham
Old 04-12-2016, 06:21 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
I have been running the same lc-1 for over 5 years now. No issues. My friend has been running the same lc-1 for over 3 years and moved it to 3 different vehicles.
My game is legit,
Old 04-12-2016, 06:34 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
I didn't think it was the lc-1...not much can move.
but I noticed the battery had moved quite a bit on that sharp turn...
maybe a loose connection?
team graham
Old 04-12-2016, 06:42 PM
1/11 sssss2094
You need to shoot the lc-1. Repeatedly.
Old 04-12-2016, 07:34 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Can anyone comment on the terminals?
is there better options I should be looking at?
does tool maker make a terminal with 2 1/0, 2 4awg and 2 8awg?
I have 2 batteries, 1 1/0 amp, 1 4awg amp, an 8awg for stock power, a 4awg from alternator, and 2 14awg for volt meter.
open to any suggestions.
I'm gonna try checking the kicker dual 1/0 ground block I attached in place of the stock ground.
team graham
Tags
graham
Pioneer DEH-880PRS w/ pico fuse issue and flex ribbon issue groundpound4200 Broken & Non-working equipment 3 04-15-2013 06:58 AM
PM Issue CROSSFIRE tC Announcements - Suggestions - Feedback - Support 46 04-27-2011 10:09 PM
day day 2001 impala rebuild daymian01 Member Rides & System Pictures 68 12-30-2010 11:22 PM
Day day 2001 chevy impala rebuild after world finals daymian01 Build Logs 24 12-28-2010 07:49 AM
Would you prefer a 5 - 8 hrs/ day or 4 - 10 hr/day work week? Patrick Simmons Off Topic Chat 32 03-03-2009 05:56 PM
