!!!!HELP system noise HELP!!!! - Car Audio Classifieds!
Old 04-15-2016, 07:21 PM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
Default !!!!HELP system noise HELP!!!!
I have a 2015 chevy malibu, it has the my link system, so there are no current interfaces to integrate an aftermarket radio into the stock location. I currently am running the 8000 series stinger 4 ch rca's tied into the factory system by the LOC LP7-4Pro line output converter by pac. I had a set of knu krystal 4 ch's in there and one of the 4 lines went bad, so I replaced the rca's.
I have a ton of alt wine coming thru the system, and when the hid's are on, a buzz....
I have 0 gauge wire run both power and ground from the front to the back. power wire is run down the drivers side of the car *(battery under the hood and the small other battery on the same side in the trunk) rca's down the passenger side, never cross paths.
when the rca's are disconnected there is no noise.
I have tried grounding the rca's at the amp, to a ground,
i've had the power and ground wire run off the back battery
and i've had now 2 different sets of rca's *(nice rca's) in the car and continue to have this issue...
what is the next step?
a good quality noise suppressor? and if so which one
[email protected]!!!! its embarrassing to drive people around with this noise, and not to mention ANNOYING!!!!
Yep... I'm an AMI NUT HUGGER>.. HE's the master of my wood
Current scores to date as of 12/5/2010:
Sealed 152.9
Outlaw 156.6
Old 04-15-2016, 07:56 PM
You know the problem is upstream of the amps, so it's either the stock headunit or the LOC. I'd suspect the LOC first. Have you tried running a ground from the back battery (or amp) to the LOC ground?
Highs On Bass (04-15-2016)
Old 04-15-2016, 08:03 PM
I'm F*CKIN Sexy!
0/11 sssss2132
i haven't yet, I will however be trying that on sunday,
Sealed 152.9
Outlaw 156.6
Old 04-16-2016, 10:03 AM
0/11 ssssssss5
Go buy an AudioControl LOC.
Old 04-18-2016, 11:24 AM
Blackone1125's Avatar
0/11 ssssss107
Problem solved?? If not, try adjusting the gain controls down on the LOC until the noise is no longer audible.....
1998 BMW 540i
Headunit: Stock DSP; Hifonics MX-1
Front Stage: Cerwin Vega 5.25's
Rear Stage: OEM 5.25's
Sub: RE Audio SX 10.4
Amps: Rockford 400.4 & bd1000
Old 04-18-2016, 11:33 AM
Mecp_advanced's Avatar
0/11 sssssss73
Throw the PAC line output converter in the Trash. Get a audiocontrol There entry Lc2 Is pretty Affordable if budget is a issue.
Old 04-18-2016, 11:37 AM
0/11 sssssss73
I would try this. Ground the loc same place as your amp is. If that doesnt help. Then maybe just try hi level in if your amp has it? or Eliminate the noise completely. Get rid of that cheap passive loc.
Old 04-18-2016, 08:00 PM
I'm F*CKIN Sexy!
0/11 sssss2132
the pac lp7-4 isn't too bad, found the issue, there was a second ground for the audio *(optional but yeah) moment it touched the factory radio chassis it was gone!!! idk how I missed it lol. but its fantastic.
Sealed 152.9
Outlaw 156.6
Old 04-19-2016, 11:08 AM
0/11 ssssss107
Great news!
1998 BMW 540i
VW Passat TDI (w/ Fender Audio System) System Suggestions jayu969 General Car Audio Discussion & Questions 3 11-02-2015 11:03 AM
Jeep Grand Cherokee Full system - Alpine Type R Question and system advice needed Murphys law General Car Audio Discussion & Questions 7 01-18-2012 06:48 PM
Whine noise through speakers and subs have motor noise got160s? General Car Audio Discussion & Questions 7 06-16-2010 07:59 PM
a whine/ screah noise noise from my sub aturcotte127317 General Car Audio Discussion & Questions 27 10-28-2008 07:50 AM
