Longer or shorter port length? - Car Audio Classifieds!
Old 04-18-2016, 07:28 AM
Brand New Members
0/11 ssssssss3
Default Longer or shorter port length?
Hey everyone i need help designing my port for a 4th order. Does a longer or shorter port length affect loudness? Im doing two sundown x 10s in 3 cubes ported. a 8x8 square port tuned to 47 would be about 19 inches long. And a 6x6 port tuned to 47 would be around 9 inches long. Thanks
Old 04-18-2016, 08:41 AM
massivespl's Avatar
0/11 sssss8409
Going from 8x8 to 6x6 will affect the way it sounds as your shrinking port area a good bit... Start with 8x8 if you want and shrink
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 04-18-2016, 11:06 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
The longer the port length, the lower the tuning. Shorter the port length, the tuning will be higher.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
really need help with port length c.bakerdude General Car Audio Discussion & Questions 11 12-07-2013 12:15 PM
Physical port vs port length? Twitney181 Enclosure Discussion & Design Construction Help 7 03-29-2013 11:38 PM
Port Length vs. Physical Port Length nicholask1993 Enclosure Discussion & Design Construction Help 28 10-21-2011 03:01 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
