upgrading my door speaker - Car Audio Classifieds!
Old 04-19-2016, 08:29 PM
0/11 ssssss313
Default upgrading my door speaker
Im buying new speakers for my doors my question is could i use the stock wires from headunit to the amp or do i have to buy new wire?
Old 04-19-2016, 08:34 PM
0/11 ssssss313
4 pwx 6.5" crescendo pro audio mid range
Old 04-19-2016, 09:10 PM
Mayhem's Avatar
0/11 ssssss175
If you're running an amp(s) to your speakers you can new wire from your amp to your speakers.
If you use your HU stock wire the only way you would get the signal from your amp is if you splice your wire.
If you would like to list your vehicle, size of your door speakers, and amp, we would gladly recommend you some speakers to fit your application.
I fart at 30hz
Old 04-19-2016, 09:23 PM
0/11 ssssss313
My concern is will it catch on fire with 100rms going to each speaker on the stock wires also what would be wrong with splicing into the factory wires
Old 04-20-2016, 12:50 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Some people choose to rewire with everything fresh...and use thicker wiring. I have my CDT comps running from an amp from a small amount of factory wiring running 75 watts or so....ain't no way there gonna catch fire UNLESS you use too small of a wire gauge and really crank those speakers.
You should be fine running that wattage on the factory wiring, unless you were running hundred's of watts, then I'd say change out the wiring. I ran 16 gauge which should be fine with you also if you choose to use that same gauge.
I sorta did with my s10 here's a few pics Notice the 3 top screws on the speaker when I 1st removed the door panel lol. Whoever installed them should be shot. No screws on either side, nor the bottom. Also got rid of that thick wire harness.....it's only 2 wires coming out of it. Unnecessary to have imo.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 04-20-2016, 12:55 AM
Mayhem's Avatar
0/11 ssssss175
You could be fine with using the factory wire but you never know.
You can get some 16/14/12 CCA for cheap and will cause no problems.
I fart at 30hz
Old 04-20-2016, 05:15 AM
0/11 ssss12531
I would use OFC myself but that's me.
Some people like the CCA vs. OFC but as Mayhem said, why take the chance something could happen later on down the road. I'm a do it right the 1st time type of guy.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
The Following 2 Users Say Thank You to Boomintahoe For This Useful Post:
colorblind83 (04-20-2016), Mayhem (04-20-2016)
Old 04-20-2016, 07:13 AM
Red Light Ear Rapist
0/11 sssss1397
if your doing 75-100 watts on pwx's its a waste of time, they are power hogs and need it to get loud, the un's will sound good on 100 watts, or switch to another brand.
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 04-20-2016, 07:46 AM
aqlover's Avatar
0/11 ssssss737
I just went through the same thing. I ran all new 16 gauge. Never know if you're gonna be upgrading in the future, might as well do it only once.
What is this ES-PEE-EL you speak of?
Old 04-20-2016, 08:28 AM
Mayhem's Avatar
0/11 ssssss175
For real?
So you think this wont be worth it? Rockford Fosgate R600-4D 600W 4-Chan Class D Prime Amplifier
I want to get an amp for mine but still not sure what to get.
I fart at 30hz
door speaker questions Slogging General Car Audio Discussion & Questions 15 05-12-2014 07:59 PM
Door speaker mounting help sherrod833 General Car Audio Discussion & Questions 5 06-07-2012 02:35 AM
WTB: Door Speaker Templates Coolwazabi Wanting to Buy (WTB) 0 06-09-2011 07:36 PM
Door speaker amp? Dunbar91 General Car Audio Discussion & Questions 16 10-06-2010 09:25 PM
door speaker options STRATUSBEATZ General Car Audio Discussion & Questions 3 04-01-2010 04:24 PM
